First post, by Trekkie4
Hey guys, I have another question...
I have a machine that's running both Voodoo2 and Voodoo3 at the same time. Now, DirectX is not much of a problem, I can easily switch between the cards, but Glide on the other hand is giving me problems... I've managed to find & download a small utility called Driver Switcher (aka Glide Switcher), and I've successfully loaded both V2 and V3 drivers into the app, but for some reason none of the cards seem to be working this way...
I don't suppose you guys have an idea on how to make this thing work? The idea is to use V3 for primary gameplay, while the Voodoo2 is meant to be a backup, for the compatibility reasons. As we all know, many games have the compatibility issues with V3, which is why I've decided for both (if possible?)
Reply 1 of 16, by rodimus80
My suggestion may be a bit unorthodox and timely. But what if you threw in a 3rd card and dual-booted? One OS for Voodoo 3, the other OS for Voodoo 2 and 3rd card?
Reply 2 of 16, by Trekkie4
No, I'm afraid dual-boot is out of the question... This is an old Pentium 3, 500MHz with only 10GB of disk space 🤣. I wanted that authentic retro thing, but thank you for the idea, nevertheless. Besides, I already have 3 cards inside this system, I'd rather not go for 4th one... 1x Voodoo3 2000 (AGP) and 2x Diamond Monster 3D II 8mb, paired up in SLI.
Which reminds me, I forgot to mention this earlier - I'm running Win98 SE.
Reply 3 of 16, by leileilol
I've done this before by installing Voodoo2 then Voodoo3 drivers, in that order, so V3's glide and ICD stuff overwrites the system - from there on you can slip V2-specific Glide DLLs into your games' folders from the V2 driver set to use the Voodoo2 instead.
Reply 4 of 16, by Trekkie4
Cool, I'll give it a try. Thanks bunches!
Reply 5 of 16, by sepultribe
have you tried hardware profiles?
Reply 6 of 16, by Trekkie4
Not sure I understood your question, but the problem has been solved, yeah. In the end, I've worked out the problem with Glide Switcher, so now I have a fully working combination of Voodoo3/Voodoo2 cards 😀
Reply 7 of 16, by sepultribe
did u look inside the pdf in the link I posted? anyways it doesn't matter since you found a fix, cheers
Reply 8 of 16, by Trekkie4
Oh, wow! I feel so stupid now, I totally missed your link... But yeah, I've worked it out without too much hassle. Besides, I'm not sure if this kind of setup could apply on Voodoo2 cards, since they're not really video cards, just video graphic accelerators (no 2D support) Thanks anyway though, I appreciate the help 😀
Reply 9 of 16, by svfn
so if using them together, can you use Voodoo3 for the 2D instead of a separate 2D card that Voodoo2 needs?
would i need to passthrough from Voodoo2 to V3? or it will be handled by V3 as default?
SS7: K6-2/350 | FIC PA-2013 2.1 | 32MB PC-100 | 3dfx V3 2000 AGP | AWE64 CT4520 | Win98SE
On MobyGames
Reply 10 of 16, by The Serpent Rider
Voodoo 2 don't need "2D" card at all for 3D rendering.
Reply 11 of 16, by Trekkie4
You DO realize that you just bumped 4yr old conversation, do you?
As for your question, yes - you could theoretically use Voodoo3 for 2D. In fact, you have to do it since Voodoo2 doesn't do "2D environment". But IMHO, it would be a waste of resources because Voodoo3 is as capable (if not even better) than Voodoo2, in SLI. But yes, theoretically it is possible, as Voodoo2 doesn't care for other card, as long it provides 2D graphics. And yes, you DO need passthrough for this kind of layout, just like you would need passthrough cable for any other card. Unless you want to use Voodoo3 as your Glide/D3D video hardware, in which case you don't really need Voodoo2 to begin with. So there, hope it makes some sense 😀
@The_Serpent_Rider
True - but Windows does require "2D" video adapter to work. In fact, you can't boot up your system without 2D card, so therefore Voodoo2 will require additional 2D card, in order to work. But once you switch into 3D accelerated mode (as they used to call it, back in a day), Voodoo2 takes over leaving 2D card idle in the background.
Reply 12 of 16, by svfn
yea i know it's an old thread but i don't want to create a new topic when it can be discussed here with relevance and for future reference.
thanks Trekkie4, yess that makes sense 😀 i guess it depends on whether my build has an AGP slot for the V3.
On MobyGames
Reply 13 of 16, by The Serpent Rider
You don't need it at all, back then it was just convenient.
Windows - yes. Old arcade boards with 3dfx - not exactly. Also Linux in theory.
Reply 14 of 16, by Trekkie4
You can always use the PCI card for 2D adapter, it doesn't matter if you don't have AGP card (or slot). Back when I 1st started with retro hardware, I was using low-end AGP & PCI video cards for 2D & Voodoo2 for 3D environment. Models like ATI Rage IIc for example, Matrox Mystique, SIS 6326, S3 Trio 3D/2X & similar. But then, at some point I realized that some games work better in OpenGL and/or Direct3D, so I swapped them out for better models, cards like Rage 128, Vanta/M64 & GeForce2 MX. And it works perfectly, Voodoo2 handles Glide-powered games, where the AGP card takes over all other titles that are having problems with Glide, or not compatible with 3dfx at all.
The Serpent Rider wrote:
You don't need it at all, back then it was just convenient. […]
Technically no, you don't need pass-through cable for Voodoo2 card to work. But if you don't use one, you need to manually unplug t he monitor from the primary video source (2D card) & plug it into Voodoo2 each time you're using it. Otherwise you can't "see" the output of Voodoo2, since the video signal can't be internally bridged to primary 2D card. But with that being said, Voodoo1 & Voodoo2 were sold with passthrough cable included with the card, so I would say that it was a necessary requirement. Or at least highly recommended 😉
And yes, I was referring to Windows - Windows 98 in particular as all my retro machines, all 30-something of them are running Windows in various shapes & forms.
Reply 15 of 16, by Baoran
I never installed voodoo 2 drivers in win98se. I just installed voodoo 3 drivers for win98se and left voodoo2 for dos glide games.
Reply 16 of 16, by The Serpent Rider
That's not a problem with multiple inputs.
