First post, by super-digger
hallo,
i have a real big Problem by the configuration of my dosbox tool.
My System (real):
Win 7 on Intel core duo CPU T6600 @ 2,2 Ghz , 4 GB Ram , 64 Bit
Prolific USB to Serial COM-port with RS232 PL-2303 XA / HXA - RS 485 Converter
FTDI USB to Serial Converter
My System (Emulatetd)
486 DX2 66 Mhz 8 MB Ram
COM 1 , 9600,8,n,1 Hardware Float Control
COM 2 , MPI 187,5 KBaud --- DP 1,5Mbaud Connection to Mashine NCU 572 CNC
DOS / WIN3.11
Software - NC -DDE , DP Mill , MMC Systemsoftware (Siemens) same specs like Step7 software
Problem :
The Software is running perfect ( after modification 😉 )
but i can´t connect to mashine over COM2
COM1 error Desired Serial mode not supported (9600,5,n,1) (it´s not tragic , don´t Need it )
COM2 error Framing 709, Parity23, Overrun RX:0 (IF0:0), TX:0 , Break 0
Framing and Parity are different sometimes
Have tried many configurations on dosbox.conf , but there is no Chance.
i´m in big Trouble, i need this Mashine realy quick , so please help me.
and sorry for bad english, ist not my favorit language.
