pojo wrote:It's the one in the first link. This pic is before cleaning. 😵
I remember that I once (in my early days of building computers as a hobby) had the same problem with the same type of cooler and I had very few spare parts back then.
I cut out the original fan which had completely seized up and taped a new fan onto it (onto the circle part of the plastic). It sorta worked I think, but I don't remember if I ended up building a rig back then to see how that "solution" faired.
You could also somehow mount a new fan directly onto the heatsink, but somehow I find screwing a new fan onto that tiny heatsink a bit...messy or something.
I wouldn't run this one without a fan btw
Can the heatsink be removed btw? If it can, then I'd try and mount a (small) fan to the heatsink.
But the best solution would be to mount a new (bigger) heatsink to the slot 1 CPU, though I don't remember if there were differences in how the heatsinks were mounted on the new and older Slot 1 CPU's
