First post, by Robert_Tang
Dear All
How to copy content from txt to DosBox window??
Help! 😢
Reply 3 of 9, by Robert_Tang
Thanks for Jorpho
Actually, I need to copy content from Excel to DosBox windows directly. There are too many recodrs need to copy to DosBox window manually every day. Is there any command for this case? Who can help me!!!
Reply 5 of 9, by Robert_Tang
Hi,collector
I did not use DosBox before. Can you help me on this case step by step?
Thanks you!
Reply 6 of 9, by Jorpho
There are many guides out there regarding the installation of XP in a virtual machine; see for instance http://www.pcworld.com/article/2139983/compat … al-machine.html .
Alternatively, your DOS program will probably run just fine in the 32-bit versions of Windows 7 and 8.1. Or you could use Windows 7 Pro or Windows 7 Ultimate, which include "XP mode", which is basically a pre-configured virtual machine.
Reply 7 of 9, by Robert_Tang
Unfortunately,the old Dos Program will crash in XP mode or other virtual machine. DosBox is my last hope. But I have to copy content from Excel to DosBox windows directly. There are too many recodrs need to copy to DosBox window manually every day. Is there any command for this case? Who can help me!!!
Reply 8 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
No, there is no way to do this this way. You might want to look whether you can convert the excel to something the program can load via a file and not copy/paste
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 9, by konc
Try another virtual machice application (eg. VirtualBox) with pure dos installed, without windows. It should work just fine
