First post, by Maraakate
- Oldbie
I'm looking for a video card that supports S-Video (ideally) and/or Composite Out for recording some demos that don't display properly or work at all in DOSBox. Ideally, it has to be on the list of supported stuff by Univbe/SDD as some demos required the use of VBE 2.0 specs.
The target machine I am using for this will be:
Pentium 1 with MMX 166MHz
64MB EDO RAM
Gravis UltraSound Max w/ 1mb
Yamaha OPL3-SAx ISA
Right now there is an S3 Trio64 which works great for these demos. If there was an S3 card that had this function I would be interested. It really doesn't matter who made it as I am not using an OpenGL stuff.
I have a P2 400MHz with a Voodoo 5 5500 and even have a few V3 3000 cards that have TV-Out but unfortunately SDD does not support these cards to add the VBE 2.0 mode.
