Thought folks would like to know that Hyllian was able to provide a shader version xBR compatible with DOSbox's shaders...
https://mega.co.nz/#!MJABWYJD!His25cu38 ... JJof6RWeh4
kolano wrote:Thought folks would like to know that Hyllian was able to provide a shader version xBR compatible with DOSbox's shaders...
oasis789 wrote:kolano wrote:Thought folks would like to know that Hyllian was able to provide a shader version xBR compatible with DOSbox's shaders...
Great, thanks! How do I use this?
pixelshader=5xBR-v3.8c.fx forced
kekko wrote:kolano wrote:Thought folks would like to know that Hyllian was able to provide a shader version xBR compatible with DOSbox's shaders...
hmm, this actually looks like xBR scaler, not xBRZ
xBRZ is an evolution of xBR
also see this post with comparison images: viewtopic.php?t=34125#p287379
robertmo wrote:HQx is still far superior than xBZR cause it can detect and than filter similar colors. So it would be good if that technique was added to xBZR too. Compare the large clay bottle below.
2mg wrote:So, I can find only old 5xBR from now outdated Gulikoza's page in a collection of shaders.
And I can't find xBRZ in it's .fx form anywhere.
I'd really like to use latest xBR and xBRZ and hybrids in DOSBox, so, could someone provide some links for those shaders?
kolano wrote:Yes, I'm not sure if there are shaders compatible with DOSBox in the repos I posted. Hyllian provided me a fairly up to date version compatible with DOSBox in the Higan thread though, which he posted at...
https://mega.co.nz/#!MJABWYJD!His25cu38q78urRDJqy0jylnTxHq1FMAzJJof6RWeh4
...I presume there's some Amiga emu that uses .fx shaders too, explaining the "for Amiga" bit on the filename.
Dominus wrote:Dosbox does NOT use ANY scaler. There is Guliloza's patch and Inofficial Dosbox builts that use that patch. Since this patch is Windows only, the chances that it gets into Dosbox are slim or probably non-existant.
You could try getting Gulikoza or someone else to adapt the patch for other shaders support...
FeedingDragon wrote:Shader use "in general," though, is not platform specific. Any chance of cross platform use of them in the future?
Dominus wrote:The same applies, someone would need to do it and so far no one has stepped forward. I would like this myself;)
Dominus wrote:Yhkwong is just using Gulikoza's patch, he's not adding original stuff to it. Not to mention he's kind of MIA for mobths now.
Dominus wrote:You could try getting Gulikoza or someone else to adapt the patch for other shaders support...
Users browsing this forum: No registered users and 3 guests
