Ultimate PowerVR SGL card/rig/games?
Reply 40 of 64, by Gona
subhuman@xgtx wrote:
Many thanks; it is good to finally see results. A shame that those demos don't work...
How does the card run Ultimate Race? Does the game run with the fancy shadows on the cars?
There is no shadows at all.
The detail settings:
The demo:
The same as with v3.1.1.36 (4.11.01.10035) and v3.1.1.101 (4.11.01.10055) drivers,
but with v3.2.1.2 (4.11.01.10079) driver the Ultimate Race cannot start it writes:
"One of the library files needed to run this application cannot be found."
"The SGL.DLL file cannot start. Check the file to determine the problem."
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 42 of 64, by subhuman@xgtx
Gona wrote:
There is no shadows at all. […]
The demo:
Again, thanks.
Very interesting.
That confirms what I suspected- No infinite planes support, no dynamic shadows.
Bear in mind I usually post to the forums using my old systems.
Reply 45 of 64, by VooDooMan
I would add to the working list the following games:
Quake 1 (MiniGL)
Hexen II (MiniGL)
Quake 3 Arena (Techland SGL miniGL)
Crime Cities (Techland SGL miniGL)
Unreal
Unreal Tournament
Die By the Sword
The Fifth Element
Ultimate Race Pro
I confirm that Tower 4 and Tower 5 Demos refuse to work.
So far I did not manage to run:
-Sub Culture
-Mechwarrior 2
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 46 of 64, by leileilol
Interesting that the alpha channel is inverted on Techland MiniGL with the PVR2...
*notes down on things to fix
Also is that UT shot in Direct3D or PowerVR SGL? (looks D3D to me) Be sure to uncomment sgldrv.int's lines to activate the driver, and maybe use KernelEx if it doesn't work.
Ultim@te Race Pro is Direct3D fyi, done when Direct3D matured enough
Debian's fucked
Reply 47 of 64, by VooDooMan
Well, I sm not so sure about that... I deleted those slashes in the sgldrv.int file, I can now choose the option "Power SGL for Windows" the game starts with that option but it is still rather slow even in low resolutions. When I check in the game options the Video Driver it says "VideoDriverClassName" - So I cannot be sure whether it is D3D or SGL working. How Can I fix that?
I would also try to play Serious Sam and MDK2, how did you get it working?
Reply 48 of 64, by leileilol
If it doesn't look like this then it's not working. Also low resolution SGL (320x240) should be ~60fps+ on PCX2 at least, and VideoDriverClassName usually is a sign of it not actually loading the driver, hence my suggestion for using KernelEx to load the game since it's a mysterious workaround.
I got MDK2 to work by naming the techland sgl minigl as 3dfxvgl.dll then putting that in Windows/SYSTEM, as MDK2 is a picky one that strictly uses drivers from the Windows System folder.
Debian's fucked
Reply 49 of 64, by Stiletto
I have to say, VoodooMan, seeing your posts regarding your Neon so soon on the heels of your "I threw away all these cards" post made me also suspect this as some sort of prank. But I talked myself out of it by asking myself "why would anyone bother to do that?..."
do the Fandango!" - Queen
Stiletto
Reply 50 of 64, by VooDooMan
Thanks! I see on your video that you use the non-GOTY edition. I use the GOTY edition, I am not sure if that is the case but perhaps I should try the "clean" edition as well?
On this video you can see the Video Driver name: "PowerVR SGL for Widnows".
https://www.youtube.com/watch?v=jJYCFi2GPrw But I have no idea what edition that is.
The problem is that I do not kow how to use that KernelEx?
I will try that trick with MDK2 this Sunday 😀
What about Serios Sam? you use the same trick?
Yeah, I know it was stupid... but it was fun as well ;P
Reply 51 of 64, by idspispopd
See Re: 3D Accelerated Games List (Proprietary APIs - No 3DFX/Direct3D)
d1stortion wrote:
Unreal 224v patch breaks SGL support (PowerVR question still appears at startup, but renderer falls back to software). Assuming that this is intentional, 221 beta is the last version with official SGL support, if this list is complete. Unreal Gold lacks SGL completely.
Kernelex causes it to work on all vanilla versions.
Can you see which version GOTY is? My guess is that it's rather new, possibly the latest version.
Reply 54 of 64, by VooDooMan
I can confirm and add to the working list:
Actua Soccer 2
Die by the Sword
The Fifth Element
Hardwar
Metal Fatigue
MDK
Motorhead
Nightmare Creatures
Star Trek The Next Generation: Klingon Honor Guard
Turok: Dinosaur Hunter
Ultim@te Race Pro
Unreal
Unreal Tournament
Wheel of Time
Rune
Deus Ex
Half-Life (SGL miniGL)
Hexen II (SGL miniGL)
Quake (SGL miniGL)
Quake II (SGL miniGL)
Games that did not work so far:
Sub Culture
Mechwarrior 2: PowerVR edition
Tomb Raider
Tomb Raider: Unfinished Business
CyberTroopers: Virtual On
Interstate 76 Gold (has to be tested once again)
POD (has to be tested once again)
Games to be still tested:
3D Shooting Maker
A Train No. 5
Actua Club Soccer
Actua Golf 2 -
Actua Ice Hockey
Actua Soccer
Actua Tennis
Buggy
Enigma
FIFA Soccer 98: Road to the World Cup
Flight Unlimited
Hardcore 4x4
Moon Racer
Nirgends
PureVex
ReLoaded
Revolte!
Resident Evil
TNN Outdoor Pro Hunter
Reply 55 of 64, by vetz
Have you encountered the problems Gona mentioned in his post with MDK, Ultimate Race Pro and Metal Fatigue? Also have you actually tested Rune and Deus Ex? PowerSGL support is not official in those games and is a bit buggy.
EDIT: Nvm Ultimate Race Pro, I can see it is missing fog in the screenshot you provided.¨
If Actua Soccer 2 works, then there is a big chance Acta Ice Hockey and Actua Golf 2 also will work as they use the same engine. Actua Soccer and Actua Club Soccer uses an earlier version and may not work.
Purevex, Moon Racer, FIFA and 4x4 exist as demo versions, you can find them in the list in my signature.
Reply 56 of 64, by VooDooMan
Yeah, I had the same issues playing MDK. I did not notice in Metal Fatigue because I did not play that game long... I launched Rune and Deus EX with powerSGL support - I am 100 percent sure of that, and they worked fine 😉 here some images of Rune WOT and UT:
I will test the games you mentioned when i find the time, thanks!
While testing some games I had the impression that they would normally run with the card but they didn't perhaps because of my lack of knowledge how to run them or maybe I just had the wrong version of the game... Still have to work on that 😉
Reply 57 of 64, by VooDooMan
Here’s a little comparison chart of Matrox M3D and Videologic Neon250. I ran those games with the support for PowerVR SGL. Testing machine was ABIT BE6-II @ Penrium 3 600 MHz. You can see that Matrox M3D is even 3 times slower in some cases...
Reply 58 of 64, by sliderider
It looks like Neon 250 is only good for putting in a picture frame and hanging on the wall if it's game compatibility is so bad. 😢
