Tips for storing CPUs
Reply 20 of 23, by PhilsComputerLab
vetz wrote:
I store them in jewel cases. I take out the inner plastic and then I can fit 2-4 CPUs depending on size.
Like this?
Reply 22 of 23, by PhilsComputerLab
Good idea.
Reply 23 of 23, by JaNoZ
Vetz does it alright putting esd safe foam underneath.
As cpu's can shift or move around in the jewel case high static energy can be generated as jewel cases are not esd safe at all.
You keep those processors from moving around, or you are gently killing them when youre moving them around and if they are moving inside fast.
If youre storing them for gold scrap only it is no problem of course, otherwise place the cpu pins on esd safe foam.
