Reply 20 of 34, by ODwilly
haha hey old computers are quirky. It is funny what they dont like. i went through 8 sticks of ram to get an emachines to boot with 1gb. it was soooooo picky!
Reply 21 of 34, by ReeseRiverson
I had a Packard Bell motherboard do that. It was insane, but sadly I never could use the board for anything. The keyboard port ended up not functioning anymore, kept on saying keyboard error... it was a nice motherboard too... Intel 486 OverDrive chip man! Oh well. I tried everything I could to try to fix that but... 😵
This Acer will certainly be quite special to work with at least! 😀
Reply 22 of 34, by Bullmecha
Email on its way Reese, hope it works =)
Just a guy with a bad tinkering habit.
i5 6600k Main Rig
too many to list old school rigs
Reply 23 of 34, by ReeseRiverson
Many many thanks to you! I so appreciate it! 😎
It worked out pretty good. Only problem was the mouse drivers on the floppy for it's own gui wouldn't load. Weird characters in the file name, but that doesn't effect anything really. The numbers it asks for on the side of the tower worked as well!
Now I believe the Acer CPR CD-ROM here is a slight different version than the one we originally had with our tower due to some very minor differences, but regardless I'm quite happy with how things turned out. 😀
Some pictures of all the on-going process.
The last picture was one of the things that were different. From what memory I have, it wasn't even saying Buttons for DOS on our old machine, it was a menu similar with boxes. Probably something Acer may have customized more back then. Whether this was an earlier or later version of the CD-ROM, I don't know. I'm not going to complain either. 🤣
Reply 24 of 34, by Bullmecha
Glad I could help you get it going again 😎
I don't own an Acer anymore myself. I did have a Pentium 75 desktop model back in the day though, probably where the disk came from.
i5 6600k Main Rig
Reply 25 of 34, by Artex
MmmmmmMmm. Do I spy a Roland SC-55 or 88 and MT-32 modules back there? Noice!
Reply 26 of 34, by ReeseRiverson
Sounds like what I once had. Though thanks so much again!
Yep, the SC-88 and MT-32 is right!
Reply 27 of 34, by Anonymous Coward
It was almost certainly a bad keyboard fuse. The fuse is usually soldered to the motherboard near the keyboard port. They can be replaced with a soldering iron. It's a pretty easy fix. If you still have the board you can try it.
Reply 28 of 34, by ReeseRiverson
Yeah I do have that Packard Bell motherboard still, actually. Some keyboards refused to work, and one did sorta work, but the lights were very dim. I was thinking it was a voltage issue, before.
Reply 30 of 34, by ODwilly
Oddly enough my 486 board has the same issue, but the keyboard works and It has never had any negative effects. Does your 486 board have a removable keyboard bios by any chance?
Reply 31 of 34, by ODwilly
Also I just want to add in that I am REALLY jealous how white your Acer is. Mine the plastic is all yellowed and aged looking
Reply 32 of 34, by ReeseRiverson
I'll have to take a look and find out. It's kinda stored away at the moment.
Hahaha, well, I hear you could restore things to being white again. I have information saved in an email somewhere, do you want me to find it for you?
Reply 33 of 34, by ODwilly
Oooh do you mean Retro-brite? I think that is what it is called. Im pretty sure that there is a thread around here somewhere about that to. Thanks but I will hold off, to many systems and not enough time 😊 my dang SSD died this week.
Reply 34 of 34, by ReeseRiverson
Haha, I know what you mean. I never tried Retro-brite either. I need to on a couple of IBM 5150s I have here. 🤣
Someday I may get to everything.
