Reply 1 of 7, by elianda
- l33t
http://mail.lipsia.de/~enigma/neu/pics/et4000.jpg
It is 40 MHz, as it is written on the socket.
Youtube Channel
Reply 2 of 7, by SarahWalker
- Member
It's unlikely to be used - the chip above the socket is an ICS1394N pixel clock generator used instead of discrete pixel clocks (hence all the blank spaces on the left hand side). The socket is most likely a holdover from a previous version of the design. Possibly fitted by accident?
Reply 3 of 7, by Stojke
Reply 4 of 7, by smeezekitty
wrote:Thanks for the values!
Also, that might be, but from all the pictures i could find using google image search all that had socket have a chip in it.
The easiest way to know is just to try it
Reply 5 of 7, by okidoki73
have more or less the same card as you and this is whats is in that socket on my card
Reply 6 of 7, by HighTreason
- Oldbie
Had a similar card. Also 40MHz. I know because the card died years back and I salvaged that oscillator for something else which I had my hands in today... Doubt it would kill it if you tried one with the wrong clock anyway, it probably just wouldn't work or else would produce interesting pictures on the screen.
