First post, by snorg
Let's suppose that (for whatever reason) computer technology halted with the 486 as the pinnacle of PC technology.
How much performance could have been wrung out of it before hitting a wall? Would someone have re-written the OS in assembler, so we'd have something like Win 95, OS/2 or NextStep written entirely in assembler? Would that have made that much difference?
What sort of applications do you think would exist if we couldn't simply throw more resources at them? Do you figure we would just have gone to multi-socket systems?
Reply 1 of 18, by smeezekitty
Honestly there is no need for rewriting the OS. An extended version of Windows 95 would work fine. What would be needed is more RAM and LESS BLOAT
Web browsers that don't take a 1GB of RAM and multi-gigahert processor. Like Opera 9.6 -- very functional with not much resources.
Web sites would need to be coded efficiently (like they used to be)
Video decoding is a tough nut to crack and that is one thing that would benefit from highly specialized coding to optimize for speed.
Reply 2 of 18, by RacoonRider
Then I suppose a 200MHz 486 would be out by the end of 1996 (there are 5x86 samples that can do that, and it would be just a matter of time before the technology would reach that point). The multipliers would go higher than 4x, we'd probably see FSB increase as well. More motherboards would support larger cache for higher cacheable memory limit. Socket 4 would appear as a new 486 platform featuring lower voltage. Intel then would step in and promise a new Overdrive, which would provide an "easy upgrade", but deliver too little too late.
Since the Pentium-class FPU essential to 3D gaming would never be developped, 3D gaming would have trouble evolving. Voodoo Graphics would dominate the 3D market even more due to lower CPU load, yet the market itself would be much smaller. The demand in stronger FPU would probably lead to the return of 487 or similar socket for a third-party FPU, which would turn the stock 486 FPU off. The new 487 socket would become the dividing factor between gaming/performance PC and office PC. We would probably even see top model motherboards with two 487 sockets for parallel tasking (as you remember, the original Socket 4 Pentium featured 2 FPUs). The 487 FPUs would be made by a large variety of companies, starting with Intel and AMD, then IIT, ULSI, SIS, VIA, OPTi.
This is how I see the "hot" system of 1997 if Pentium never arrived:
AMD 486X 240MHz (6x40MHz)*
2xIIT 4C87DX8 200MHz (5x40MHz)
ASUS X-487D Socket 4 + 2xSocket487 motherboard with 512Kb of asynchronous cache upgradable to 1MB
64MB EDO RAM
Matrox Millinium 4MB PCI videocard
2xVoodoo 2 12Mb SLI
Creative Sound Blaster AWE64
*AMD 5x86 would never be named 5x86 if Pentium did not arrive. Instead, it would be named "486DX6". Intel would be the first to make it and would name it in the tradition of bloating. That way x4 would be DX6, x5 would be DX8, x6 would be called DX10 in press releases, but in order to shorten things up, it would be renamed "486X" instead, bringing even more confusion to the masses.
Reply 3 of 18, by smeezekitty
I disagree. It would have struggled but there would still be 3d games. Doom runs on a 486 for example.
And I am sure there would be work on hardware graphics rendering (i.e. GPUs)
Now if GPUs were halted in the same way CPUs were, it might be another story
Reply 4 of 18, by RacoonRider
The 3D would struggle, because, in other words, it would be held back by FPU. That's what I meant 😀
Reply 5 of 18, by Scali
Yes, but I think smeezekitty means that GPUs have taken over the role of the FPU by the time the GeForce arrived, with hardware T&L.
If GPUs would evolve, they would just take over most of the FPU work, and the 486 may be quite a feasible option for 3d gaming after all.
I wonder how well a PCI-based GeForce card would work in a 486 actually.
Reply 7 of 18, by Kerr Avon
Yes, but not too much trouble. Even on the eight bit home computers of the 1980s, 3D gaming was possible, both wire frame (Elite, Starglider, etc) and filled (Driller, The Sentinel, etc). And when you look at how 8-bit computer software improved over time on any given popular machine, such as the ZX Spectrum, or Commodore 64, it does make you wonder how software for the PC 486 would have improved if programmers had to always use the same consistent hardware over a period of years.
Reply 8 of 18, by jwt27
Don't intend to hijack this thread but I had to post this. http://i.imgur.com/wA67J8Q.png
Reply 9 of 18, by alexanrs
Probably the same way things happen with consoles. I mean, who could imagine something like StarFox when the SNES was released?
Reply 10 of 18, by smeezekitty
Clearly a memory leak 😵
Honestly, if CPU and RAM wasn't growing so fast, it would probably a good thing for software design. It worse programmers to be efficient and not make horrible bloaty code
Reply 11 of 18, by mr_bigmouth_502
70 processes?!?! Holy shit. 🤣 That Opera memory leak is just absurd, but at least you could do something about the number of background processes you have running.
Reply 12 of 18, by leileilol
SLI VLB videocards with 3d daughterboards 😜
Debian's fucked
Reply 13 of 18, by smeezekitty
You're kidding right?
http://s28.postimg.org/4jyyr0ahp/process_list.jpg
Reply 14 of 18, by feipoa
A GeForce 2 MX400 worked well in my tests using an Am5x86-160 on a UMC8881-based Biostar MB-8433UUD. Using graphics cards which are more modern than the socket 3 generation of hardware is well documented in this thread, Modern graphics on a 486
An excerpt is provided below for the graphic card you inquired about. Recently, I tested Half-Life and it seems to run well in my opinion.
PNY GeForce2 MX400 64MB
Win95c
NVIDIA Detonator v12.41 for Am5x86, however I was unable to get Direct3D working (e.g. Outlaws, MDK). OpenGL works with the Am5x86 with v12.41, however Direct3D games will require a POD. NVIDIA Detonator v77.72 for POD.
AMD Am5x86-160 - GLQuake (nosound, 640x480x16) = 26.7 fps [with sound at 1280x1024x32 = 24.4 fps]
AMD Am5x86-160 - QuakeII (nosound, 640x480x16) = 15.5 fps
Intel POD-100 - GLQuake (nosound, 640x480x16) = 36.1 fps (vs. 29.2 fps with v12.41)
Intel POD-100 - QuakeII (nosound, 640x480x16) = 17.5 fps (vs. 17.3 fps with v12.41)
WinNT4
For an Am5x86, the NVIDIA Detonator v6.50 (GL v1.2.1) display driver works best, however GLQuake gives a Dr. Watson error when exiting. QuakeII yields a BSOD with relation to the sound card. NVIDIA Detonator v12.41 (GL v1.2.2) works fine with the Quakes, however changing resolutions is a little slow.
For a POD, NVIDIA Detonator v29.42 (GL v1.3.1) is the best of the older drivers, however Detonator v77.72 (GL v1.5.4) yields better Quake results.
AMD Am5x86-160 - GLQuake (nosound, 640x480x16) = 28.4 fps [with sound at 1280x1024x32 = 25.6 fps]
AMD Am5x86-160 - QuakeII (nosound, 640x480x16) = 16.6 fps
Intel POD-100 - GLQuake (nosound, 640x480x16) = 36.0 fps (vs. 31.3 fps with v29.42)
Intel POD-100 - QuakeII (nosound, 640x480x16) = 18.6 fps (vs. 18.0 fps with v29.42)
NVIDIA drivers do not work with IBM/Cyrix 5x86 CPUs in Win95c and NT4.
When switching pages in the BIOS, the redraw rate is slow.
Reply 16 of 18, by Scali
That's interesting, thanks!
It does not quite show what I was expecting though, since there are some non-T&L cards that deliver similar performance in GLQuake.
I suppose that could be explained by the fact that GLQuake's engine is not designed to take full advantage of a T&L-based GPU. It only sends very small batches of polygons to the GPU at a time, so the GPU can't really flex its T&L muscles.
It would be interesting to do some synthetic tests, such as the ones in early 3DMarks, where they just send large batches of polygons to the GPU:
http://youtu.be/M2qoFiXxCck?t=5m9s
The CPU-overhead for that test is near 0, so it may be possible that a GeForce card performs about the same in a 486 as it does in a faster system, with such tests.
Reply 17 of 18, by Scali
Hum, not sure what you mean here.
Are you confusing FPUs with pipelines? All Pentiums have two integer pipelines (U and V pipe) and one FPU pipeline. There is no optional FPU socket or chip for any Pentium as far as I know.
Reply 18 of 18, by RacoonRider
I meant internal FPU, I know there is no 587 socket... Anyway, I revised my sources and it turns out, I did not remember it correctly. Of course, I read about integer pipelines, but for some reason I thought it was about floating point pipelines, which correlated with Pentiums's exceptionally strong FPU very well. My apologies.
