Thanks 😀 I've built a list of possible PSU's to get. I'm thinking the tiny supply in my case is pushing it to power the HDD's. Mainly because sometimes there's a long pause in detecting the IDE drives. By long, I mean about 4-5 minutes. I usually power off then back on, and it goes faster the second time. Other times, it will miss a drive on the detect. Again, I'll power off then back on and it will catch it the second time. If it was the same drive every time, I'd suspect a drive trying to go out. But it doesn't, I've had the IDE go undetected (not a problem, as the driver catches it later anyways.) But sometimes it's one of the hard drives, and that is a bit problematical, as that drive won't be available.
On a similar note. I had a power outage earlier, and discovered a missing BIOS parameter that I hadn't noticed before. Pre-Powerleap BIOS, I could set it to either stay off after a power loss, come on after, or return to the previous state. Now, that setting is gone, and the system comes on after power is restored. I prefer to use previous state, or just stay off if that isn't available 🙁 Oh well, don't thing I can do anything about it.
I'll probably be getting a PSU on the 3rd (when I get my check.) Maybe the 1st depending on expenses between now and then. Now that I know what I'm actually looking for, I have a host of choices 😀 I'm also planning on getting a Cross-Flow fan. I have an extra case fan somewhere. If it's big enough, I might see about using the slot cover hack to set it up to blow down on the Voodoo cards 😀
