First post, by FeedingDragon
- Oldbie
I've tried PSU calculators, but the problem is, they are all geared towards newer machines. I currently have a 300W PSU in the system, but I doubt it's enough. I haven't pushed the system to it's limits yet, but I would like to install a better PSU before I start really pushing the tests. I have the rest of the HW pretty much finalized now, though I am considering upping the RAM to the 768MB limit. Not really worried about that, though, 512MB is probably the most it will need, as most games that can really use more than that work on my modern system anyways. That "might" change if I buy new (to me,) games.
Anyways, what's in my system now:
Gigabyte GA-6BXC Motherboard (Modified for high current AGP 2x cards)
512MB PC100 RAM (1x256MB + 2x128MB)
Celeron 1.4Ghz CPU (100Mhz FSB) w/Powerleap PL-iP3/T Adapter
Voodoo 3 3500 TV 16MB AGP
Voodoo 1 4MBB PCI
2x Voodoo 2 12MB SLI PCI
Generic 10/100/1000 NIC PCI
MPU-401AT ISA with SCB-55 Daughterboard ISA
SoundBlaster AWE32 with 32MB (28MB usable) ISA
1.2M 5.25" Floppy Drive
1.44M 3.5" Floppy Drive
BenQ DW1670 DVD-ROM Drive (Reads all Non-HD Formats)
3x 40GB 7200 RPM ATA-66 Hard Drives
The only addition I might make to that in the future is a DB for the AWE32. That's a rather large maybe, though. The only one that really caught my "ears" is the DoX-1 Korg DB. Not really ready to shell out the $250+ to get one though. Before anyone comments on the ATA-66 HDD's, they were pulled from a Socket-7 system when it's MB fried on me... Well, it was the KB chip that went out after a power surge, I really should have replace the UPS on that system when the old one went out 🙁
Am I wrong in assuming that the 300W PSU won't be enough if I really push the system? Any advice on what to replace it with would be appreciated. I don't really see a need to throw a 1200W unit in it (800W works fine for my modern system, and I really push the system at times.) I started to buy a 400W unit just a bit ago, but decided to get some advice before settling on that.
Feeding Dragon
