Reply 7140 of 53137, by VooDooMan
Am I just THAT lucky, or those cards weren't so rare afterall?
Original drivers and instruction... the box should be lying somewhere... but who cares 😉
Such a beautiful pair - brother and sister ;P
would you believe me If i tell you that I got one of those for free? 😁
Best Tualatin Motherboard
ECS P6S5AT at 166 MHz
Overclocking Pentium III
Reply 7141 of 53137, by BSA Starfire
Nice!!! judging by the last few posts it's Matrox and PowerVR day! 🤣
Reply 7142 of 53137, by vetz
Gratz!
Would be awesome if you could:
1. Test if there is any performance difference on the Neon250 between AGP and PCI
2. Test if there is any compatibility difference
3. Upload that disc to vogonsdrivers 😀
Reply 7143 of 53137, by Artex
vetz wrote:
Gratz! […]
Gratz!
4. Send that PCI version to Artex 😎
Reply 7145 of 53137, by CelGen
sliderider wrote:
King_Corduroy wrote:
I didn't buy these I got them for free but it's still cool and certainly retro. 😁
Sorry don't know much about this system yet except that it's a microcomputer with an 8088 cpu (I think) and it is not working / is missing the keyboard. It switches on and the screen works but it doesn't appear to be self testing or anything.
I don't think that's an 8088 machine. Probably a 8080/8085 or Z80. You would need a CP/M floppy if that's the case, and good luck finding software for it. Most of the CP/M repositories closed down a long time ago and there's not a lot of people sharing the software any more. There might be a couple of websites with *SOME* of the formerly vast collection of CP/M software, but I strongly suspect that much of it is permanently lost.
It's a Heath/Zenith machine. I can almost assure you someone has copies of the floppies. Mind you they won't be much use without a keyboard. I wonder if one of the cracked nuts at Geekhack had something to do with that... 😒
Go hit up the Vintage Computer Forums. I'm sure someone can help you address all your issues. At least your display shows a good raster.
Reply 7146 of 53137, by Stiletto
vetz wrote:
Gratz! […]
Gratz!
Also looks like a slight video BIOS version difference too! 😀
do the Fandango!" - Queen
Stiletto
Reply 7147 of 53137, by Caluser2000
Yip. They are damn helpful and quite a few CP/M fans there as well. Some even developing their own software.
This might be of interest http://www.classiccmp.org/cpmarchives/
Reply 7148 of 53137, by vlask
Lukeno94 wrote:
Interesting, I wonder why Matrox chose to put such beefy, long VGA connectors on the G450? Never seen anything quite like that!
Can be seen also on some GF4 Ti cards. But theyre rare and dont know why they made them so long....
http://vgamuseum.info/index.php/component/k2/ … eforce4-ti-4600
http://vgamuseum.info/index.php/component/k2/ … rce4-ti-4800-se
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 7149 of 53137, by RacoonRider
vlask wrote:
Can be seen also on some GF4 Ti cards. But theyre rare and dont know why they made them so long.... […]
Ferromagnetic filters built-in? Anyway, I'm sure it's about signal quality, the main focus of most Matrox products.
Reply 7150 of 53137, by Callahan
MSI8872 v2 (PNY GF 4 Ti 4600)
look at pcb on other side, it has a dvi section and behind second section for vga.
Simply, it can be vga conn here or dvi. Nothing less, nothing more.
Same here with Matrox:
Cpq: ap550(2x1G/256k), sp750(2x900/2MB), 5100(2xpII300)
TD-30 2xP166 NT 3.51
HP Vectra XU 6/200 2x PIIOD 512MB FPM Banshee
Super S2DG2@550/2MB SCSI 15k V5 5500
P4T533-C P4 3,06 Ti4600
Dell T700r @P3-700 V3 3500
PR440FX-2x PIIOD Voodoo 4500 PCI r320 CT1920
Reply 7151 of 53137, by RacoonRider
But Matrox has 2 long connectors and only 1 optional DVI. Aesthetics? Mine is exaclty the same on the other side btw.
Reply 7152 of 53137, by kithylin
Bigger: http://www.outfoxed.net/aiw-9800-pro.jpg
ATI All-In-Wonder 9800 Pro AGP 128MB + breakout cable. Found this at the local used hardware store that (Sadly) is closing down, everything in the store is -60% off now, so I got the card + breakout cable for $10 + tax out the door. I'm thinking I can find software online somewhere and try to use my recently bought AthlonXP 3200+ barton nforce2 board and use it as a video converting station and convert some of my older VHS's to digital videos out of the attic, should be perfect for that.
Reply 7153 of 53137, by sliderider
The Matrox is a dual head card.
http://www.matrox.com/graphics/en/products/le … /g_series/g450/
Reply 7154 of 53137, by QBiN
kithylin wrote:
ATI All-In-Wonder 9800 Pro AGP 128MB + breakout cable. Found this at the local used hardware store that (Sadly) is closing down...
EDS on Pioneer Pkwy.?
Reply 7155 of 53137, by kithylin
A local? 😲 Yes, that's the place. Everything closing. They also have a AIW 9600 back in the VGA Isle somewhere. Just loose in the bin with all the other loose cards though so it probably doesn't work. This one was hanging in a plastic bag by the front so I'm thinking it's probably fine.
Reply 7157 of 53137, by easy_john
Awesome!
Can buy it from you by double, no, triple price! :)
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 7158 of 53137, by Kodai
glutamin wrote:
Hi guys!
I bought a Yamaha DB50XG today on a flea market.
Hopfully its a working one. (I payed 0.72 USD for it)
Why do the back of the header pins look burnt?
Reply 7159 of 53137, by hard1k
That's the question I always asked myself looking at every XR385 I came across...
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
