Guess the retro hardware!
Reply 20 of 62, by TELEPACMAN
Tyan Tiger 100 😎
Reply 21 of 62, by havli
Indeed. 😀
I tried to adjust resolution of the photo to make "Tyan" logo between CPU slots semi-readable.
Reply 22 of 62, by TELEPACMAN
Cool! Here you have then...
Reply 23 of 62, by tayyare
TELEPACMAN wrote:
Cool! Here you have then... […]
40MB RLL HDD . One of these:
WD 344R
WD 384R
WD 544R
WD 584R
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 24 of 62, by HighTreason
It's a Western Digital WDC93044 as far as I can see.
40MB IDE drive, there was an A version and an X version, the X version had 8-Bit IDE and was used in some Amstrad computers.
Reply 25 of 62, by TELEPACMAN
😊 Sorry for the late reply, I took a 10 hour nap. Very nice try tayyare but HighTreason takes the prize this time, as he gave the complete model number. It's the 40MB Western Digital WD93044 ( it's the "A" version, the only one I knew of). Congratulations!
Reply 26 of 62, by PCEnthusiast
AMD Athlon 64 3000+ @ 200 Mhz, 1360x768, Realtek AC 97 HD, Genius Model. NO KB-0120, ATi Radeon Sapphire 9600 SE
Reply 27 of 62, by Skyscraper
PCEnthusiast wrote:
http://s6.postimg.org/glyh9g5mp/amd5x86.png […]
Am5x86-P75
Isnt HighTreason the one who should have posted the next picture though?
Reply 28 of 62, by HighTreason
??? Thought it was my turn? I wanted to be the one to knock the thread off it's rails. 🙁
Anyway, I'm taking my turn, here;
The attachment PHTO00112.JPG is no longer available
The entire thing (Not just the card). Have fun. 😜
Reply 29 of 62, by PCEnthusiast
Skyscraper wrote:
Am5x86-P75
Oh sorry i didn't see the post. Then i would came back a few minutes...
Reply 30 of 62, by luckybob
it is a Tyan Tiger 100 board.
here is a harder one, but should be doable:
Reply 31 of 62, by Skyscraper
luckybob wrote:
it is a Tyan Tiger 100 board. […]
This is a wild guess 😁
The CPU board in a Cobalt Qube?
Reply 32 of 62, by PCEnthusiast
It's the motherboard or CPU board in a Cobalt Qube3.
Reply 34 of 62, by Skyscraper
HighTreason wrote:
I just don't exist around here do I? 🤣
Well could it be a ZX Spectrum+ ? 😀
Dosnt look flat enough though.
I have very little knowledge about stuff that old.
Or perhaps the SCSI card is just named ZX for random reason 😀
Reply 35 of 62, by Skyscraper
This thread seems slow today so I will add yet another picture as the turn sequence seems totally messed up already.
I think this piece of hardware is retro but Im sure not everybody will agree.
I will give you one clue, this CPU cooler is between 11 and 12 years old.
Bah I just read the first post, year 2000 and older, see this one as a bonus while we wait for someone to figure out the pic HighTreason posted 😉
Reply 36 of 62, by konc
I'm confused of what's been discovered and what's not. Guys, refresh your queue 😁
Reply 37 of 62, by obobskivich
Skyscraper wrote:
This thread seems slow today so I will add yet another picture as the turn sequence seems totally messed up already. […]
Gigabyte 3DRocket - sans all of its mounting hardware and fan controller. I still want to know what HighTreason posted (so let it be "next" unless Skyscraper got it, in which case I'll have to find something), and admittedly I have no idea what it is. Searching for the product ID silked on it returns a National Instruments SCSI card (hey, if HT can use FCC IDs to look stuff up, why can't I do the same thing on his picture? 🤣 ), which may or may not be associated with a Sinclair ZX.
Reply 38 of 62, by Skyscraper
You are correct!
I have all the mounting hardware and the fan controller, the only thing missing is the Molex adapter but the header on the cooler is a "small Molex" so its not a huge issue.
I agree! The one that identifies High Treasons image should post the next one as this was both out of sequence and not according to the rules 😀 At least we bump the thread!
Reply 39 of 62, by obobskivich
Skyscraper wrote:
You are correct!
This is kind of a tangent: the "small Molex" is actually not a Molex, it's a Berg; technically a 4 pin polarized connector (https://en.wikipedia.org/wiki/Berg_connector), and the 3DRocket can run with only that connected (it will run at full RPMs though). The whole reason for the external fan controller is so the fan can be variable RPM without the LEDs blinking or dimming. In theory you could just disconnect the fan from the circuit-board on the top of it and plug that straight into your motherboard or whatever else, which would turn the LEDs off and let the system control the RPMs. I never got around to trying that on mine while it still worked though.
