Reply 400 of 590, by j^aws
Changing the subject back on-track - I've got a few questions about the SID chip:
1) How many different types of SIDs were manufactured by MOS/ CSG? I think there are at least 5, if I go by the "R5" stamp on the 8580 series...
2) If the 8580R5 is a reference sound, which of those SID types sound the most 'different' would you say?
I'm looking at enhancing the pseudo-stereo effect using two replica boards. So far, I've tried a 6581R4, and it sounds pretty much identical.
Reply 401 of 590, by Beegle
I also have a question, regarding pitch.
When I recorded songs from Ultima VI, I captured different variations of the soundtrack : Tandy 3-voice, CMS, Adlib, SSI-2001 and LAPC-I.
I noted that they all blended harmoniously, seemingly playing at the same (or similar) pitch, except the SSI-2001.
I tried playing with the jumper to switch between 0.89 and 1.02.
Yes the pitch changed, but neither option seemed to create notes at the same height as the other sound cards, making the SSI-2001 replica 'out of tune'.
Anyone had the same problem? I'll make a video if anything I write is unclear.
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 402 of 590, by RoyBatty
edit by Qbix: removed image, that doesn't add much. This isn't reddit/imgur
Also hi Shock and all, ltns 😉
Reply 403 of 590, by matze79
Did anyone tested SwinSID inside ?
Reply 404 of 590, by shock__
SwinSID should be fully transparent - so it should work perfectly.
(except for the paddles when in 8580 mode - if that feature is emulated and someone writes software for it, as the 8580 needs slightly different values for the caps there to go the full range [the values on the SSI-2001 are meant for 6581 SID chips])
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 405 of 590, by noop
Hello everyone! I previously helped bristlehog with porting the SID player to DOS and making timer synchronization code, but didn't hear from him since. Problem is that I didn't test that code, because I have neither hardware, nor the build environment he used. Every time I made a change he had to compile it and run on his card.
Can I still help?
Reply 406 of 590, by amigo-mexicano
I have two versions of SwinSID, will make tests soon and let u all know 😀
amigo-mexicano
Retro computer-and-console nerd from Mexico City!
www.videogamedose.com
Reply 407 of 590, by j^aws
Can I still help?
If you can tell us what you need us to do, then I'm sure someone here could help?
Reply 408 of 590, by Fagear
Keep us updated!
Can I still help?
Well, it seems like bristlehog has no free time for the moment... I'm a programmer also, but I don't write for DOS or Win32-console apps... And I have very little free time now also.
So I someone can do something usefull about SID player for SSI-2001, it will be much appreciated. Probably we can get source code from bristlehog for the SIDTEST app...
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 409 of 590, by noop
I think I have it. But still hesitate to buy the card itself, don't even have SID, I'm AY fan 😀. И жаба душит
My limited capacity to test it without the card is the reason why timer synchronization code is still borked.
I don't even know if the app works corectly at all for someone at this point. There were several versions of timer sync code, DOS-only with lower precision(still much higher than needed by most SIDs), incompatible with win 98 dosbox, and presumably better one that was supposed to run as win9x console app, and probably has limited CPU/motherboard compatibility.
BTW, did I hear correctly that there's SID emulator for Propeller MCU? Recently got one.
Anyway, wrote PM to Fagear.
Reply 410 of 590, by Fagear
Feels like silence here... I'll wake you up a little!
I've made one of my concepts in the hardware: PC mounting bracket from PCB!
https://youtu.be/NRmj-7oqLfY?t=15m33s (Russian language, but you don't have to listen to understand what it is all about).
The attachment SSI1.jpg is no longer available
The attachment SSI2.jpg is no longer available
The attachment SSI3.jpg is no longer available
The attachment SSI4.jpg is no longer available
The attachment SSI5.jpg is no longer available
As simple as that.
Two milled PCBs, that are assembled together by soldering. As cheap as it gets: 1-sided, no soldermask, no silkscreen (but all those can be added if needed).
This bracket provides electrical connection to the PC casing and shielding (as does metal one).
Reply 413 of 590, by shock__
Any case you get any excess ... I'd love to order one for my existing card.
[Z?]
Reply 414 of 590, by Stojke
Thats a nice idea.
Reply 415 of 590, by j^aws
If there are spares going, I'd love to order those brackets as well - ideally 2 of them for my pair of replicas. Nice choice of colour, Fagear; they look like special editions.
Reply 416 of 590, by elianda
It's not directly related by quite a curious card:
https://i.imgur.com/pfxdDav.jpg
Mating Sound Simulator...
Youtube Channel
Reply 417 of 590, by amigo-mexicano
Any info on the brackets, ready for sale Fagear? 😀 We are anxious...
amigo-mexicano
Reply 418 of 590, by shock__
I was just about to post that. The 8255 is confusing me quite a lot ... and so is the origin of that picture.
[Z?]
Reply 419 of 590, by Api
It's made in Finland. Mating sound simulator... 😵 But does it play Hubbard?
IntelSE440BX-2 256MB PII-300 Rage128 Voodoo2 SLI Vortex2 SB32 Win98SE
Asus A7N8X-E Deluxe 1GB Athlon XP2400+/XP3000+ Radeon 9600XT
FIC PT-2000 P120 Matrox Millennium 2MB Orchid Righteous 3d
