First post, by boxpressed
- Oldbie
I rescued an e-Machines T2460 and have decided to make it my main XP build. It has an Athlon XP 2400+.
It was pretty noisy, so I replaced the stock PS with a Corsair CX430 I had. Turns out that the noise is from the 60mm fan on the CPU heatsink. I replaced it with the new one that's shown in the photo below, but the noise level is the same.
Are there any brands of quiet 60mm heatsink fans? Or are they all going to be this noisy unless I replace the heatsink/cooling solution? Thanks in advance for any advice.
