First post, by keropi
Hiya!
I've been trying to setup a friend's SB16 CT2270 in a DOS 7x installation (DOS7 from 98SE but without any windows present at all).
Naturally I downloaded the CTCMBBS and SBBASIC driver packages. But the Creative PnP manager complains that I need to update settings in win98 - but there is no windows installed.
I remember a solution to this was found here but I can't find it atm 😢
Could a kind soul point me to the right direction?
TIA! 😊
Reply 1 of 10, by wbc
As I remember changing "winbootdir" string in CTCU.EXE and CTCM.EXE (i.e. in HEX editor) should be sufficient.
--wbcbz7
Reply 4 of 10, by Cloudschatze
keropi wrote:
This is not a PnP card; the use of CTCU/CTCM isn't necessary.
Reply 6 of 10, by PhilsComputerLab
If it's not a PnP card, just run INSTALL (or was it SETUP) from SBBASIC folder. If you get an error about running it inside Windows, use SETVER. During the setup the resources can be configured if I remember correctly.
YouTube, Facebook, Website
Reply 7 of 10, by Sammy
Have the card jumpers for IRQ and DMA?
I have 2 SB16.. one with Jumpers , the other not.
The card without Jumpers need ctcm / ctcu / diganose to work.
Reply 8 of 10, by gerwin
I noted this for the SB16 CT2290, which is based on the same CT1747 'OPL' controller:
Source - The card requires me to reserve an IRQ for legacy cards in the BIOS, and requires 'Diagnose /s' at every boot. CTCM does not detect it.
Reply 10 of 10, by keropi
thanks all for the help/tips !
I got the card working again after I cleaned it's ISA connector. It didn't look dirty though.
The card worked without the PnP manager , just like Cloudschatze said 😀
