First post, by comax
How to install Sound Blaster Audigy Install CD. I downloaded this file but i dont know how to install. with file disk.id ???
i mounted but , i can not eject
it is joined throuth the file
it's doesn't have setup.exe so how to install ??? pls help me
hellllllllllllllllllpllllllllllllllllllllllllllllll
Please be patient, and stop bumping your own thread.
I've already deleted your crossposted four other threads.
do the Fandango!" - Queen
Stiletto
You are not making sense. Can you provide a link to whatever you downloaded?
how to install without file setup.exe ??? pls help
pls helpppppppppppppppppppppppppppppppppppppp
You can probably get banned if you write unstructured posts like that constantly, calm down man 😀
It seems that the driver does not detect the Audigy sound card you have installed into your computer. Are you sure you installed it?
Also, are you sure it is an Audigy sound card that corresponds to those drivers?
Provide me with the following details:
1. Audigy model
2. Driver version/information (windows version)
3. Did you insert the card into your computer
4. Does the Device Manager see the card under Multimedia devices
oh i'm sorry !
1. Audigy SE 24 bit
2. window 8
3. yes
4.
It seems you are trying to install drivers for Audigy / 2 / ZS series, they are not compatible with Audigy SE.
You can use Creative drivers found here: http://support.creative.com/Downloads/welcome.aspx (Select Windows 8.1)
But it seems windows already detected and installed your card.
I already installed but it haven't creative control panel. And Audigy stereo it doesn't work.
I need stereo and echo to play paltalk.
Audigy SE is an budget version based on CA-0106 micro chip not EMU10k2. I don't think it has the control panel like other full Audigy cards.
It lacks hardware EAX, it is driven by Software EAX 3.0 (Upgradeable to EAX 4.0), and does not have Dolby Digital 5.1.
do you have teamview ?
you can visit my computer to help me turn on stereo Audigy
From what I read, Audigy Stereo Mix (what you hear) is not usable on Audigy SE under windows 8/8.1 -> http://support.creative.com/kb/ShowArticle.aspx?sid=87127
