Reply 960 of 3949, by ZellSF
Star Wars Episode 1 Racer looks much better now.
Total Annihilation Kingdoms works now, but something's wrong with the fog of war effect:
wrote:Star Wars Episode 1 Racer looks much better now.
Hmm... I have only the demo.
How should it look? How could I reproduce the fog of war? (I don't know this game, never played with it.)
Oh that seems to be a map specific fog of war effect (first map of the campaign), not in the demo, comparison follows:
Seems to be another game reliant on ATI colorkeying btw...
Another problem that's actually in the demo this time (start a skirmish without the map revealed and with unit reveals line of sight option). Fog of war doesn't work at all in dgVoodoo2 (and neither does updating the minimap):
Galshell no longer has transparency issues in the menu, but crashes when going ingame (it didn't in WIP8).
WIP9 causes Empire Earth and its expansion to no longer display anything past the intro videos. The audio plays, but the screen is...transparent. As in, nothing shows up on-screen, and nothing is clickable. Even forcing windowed mode does nothing. This also affects all 3D cards which WIP9 currently supports (dgVoodoo, ATI, NVIDIA).
wrote:I've seen a lot of this kind of 'config tweakings' from users undisputedly having no clue about what they are doing (back in the dgVoodoo 1 times).
Advanced settings should be accessible only from command line, or from an ini file or sg like that, I don't know it yet.
Good point. I hate when people blast out lists of settings without any explanation for why they think they're needed.
I fixed Galshell and Empire Earth, however still uncertain about TA Kingdoms demo. It seems to work fine for me with ATI:
(However I get unreadable text letters with nVidia, I'm gonna check it all again)
As for dgVoodoo 1, I can't blame them. It had a lot of complicated options that were hardly understandable even for a programmer. 🤣
oh, apparently it's higher resolutions that are broken. Try running it in anything higher than 640x480.
wrote:Advanced settings should be accessible only from command line, or from an ini file or sg like that, I don't know it yet.
Original Glide 3X API uses environment variables as settings. Probably, it's a good idea. For example, nGlide also uses environment variables for settings: http://www.zeus-software.com/forum/viewtopic.php?f=9&t=796
You can see in my patch how I've added special support of this variables in my NFS3 Modern Patch.
dgVoodoo can read environment setting and use it as default value when reading from ini file. It will allow for user to choose a better way for configure dgVoodoo. Environment variables could have names like DGVOODOO_SETTINGNAME for this ini setting SettingName=123 in the [DGVOODOO] section. It will be very flexible I think 😀
Best regards, Evgeny
I was just trying to play Wizards and Warriors for the first time on this rig. Looks like the only way to play it with a recent nvidia card (with recent drivers), even having tried modified exes, is with dgVoodoo 2 which fortunately works flawlessly from my limited testing.
Dark Omen
After forcing this game into window mode...
( AFAIK the game's fullscreen code is bugged because it doesn't work correctly with IDirect3DRampDevice either... )
This game appears to have two problems with WIP9:
1. Blt and BltFast FROM the primary surface fail with E_NOTIMPL.
2. Blt's with DDBLTFX_MIRRORUPDOWN fail? silently.
( edit: #2 could be related to #1, I haven't really looked into. )
Problem #1 is mostly harmless for this game.
Problem #2 causes the the menu backgrounds to be all black.
( the game loads the menu background bitmaps then flips them, I think. )
I've worked around both of these issues by rolling my own ddraw wrapper in front of dgvoodoo.
Thanks Dege for your exciting work!
wrote:oh, apparently it's higher resolutions that are broken. Try running it in anything higher than 640x480.
Thanks! Now I found the bug and fixed it.
Original Glide 3X API uses environment variables as settings. Probably, it's a good idea. For example, nGlide also uses environment variables for settings: http://www.zeus-software.com/forum/view ... ?f=9&t=796
Thanks for the ideas. Currently I vote for the ini file. 😀
But it all is not too urgent as there are only two properties that could be set independently on each other:
- colorkeying method
- paletted textures
But a few others could be submitted to the list, like number of texture stages, supported formats, RGBA order, etc. 🤣
This game appears to have two problems with WIP9: […]
Yes, blitting from primary is not implemented, but DDBLTFX_MIRRORUPDOWN should work.
Altough now that a lot of things are refactored version by version it could be implemented easily. What is more, I'm going to implement it, for the sake of the full blitting functionalty.
wrote:I noticed the resolutions in JK top out at 2048x1536 (the maximum earlier versions of DirectX allowed) with dgvoodoo but if I use WineD3D even the Downsampling resolutions I set up are available. Any chance support for higher resolutions can be added?
There's also an issue with the GOG version only showing the ModeX resolutions. I sent you a pm about it.
Any news?
La-Mulana works in WIP9 (had color palette issues previously).
wrote:La-Mulana works in WIP9 (had color palette issues previously).
La-Mulana came out in 2005, why would you need dgVoodoo for it?
wrote:La-Mulana came out in 2005, why would you need dgVoodoo for it?
...because it uses a DirectX version prior to 8? Don't be surprised - there are still modern games which have DirectX 7 as their minimum-required DX version, like Treasure Adventure Game and Lone Survivor.
A lot of Japanese indie developers still use older libraries for maximum hardware compatibility as their PC market is really, REALLY slow from the lack of brand loyalty to modern hardware manufacturers keeping the competition healthy. It's a very mixed bag similar to how PC-98 lingered for so long, so it should come as no surprise to find even a new 201X game using DX7/GL1.x.
(however in the west, a similar looking game would use Unity or XNA and require DX9 pixel shader 2.0 hardware to run minimum for no strong reason)
wrote:A lot of Japanese indie developers still use older libraries for maximum hardware compatibility as their PC market is really, REALLY slow from the lack of brand loyalty to modern hardware manufacturers keeping the competition healthy. It's a very mixed bag similar to how PC-98 lingered for so long, so it should come as no surprise to find even a new 201X game using DX7/GL1.x.
I don't really understand it because I checked this game and it's indeed DX9.
Is there an earlier release using <=DX7 maybe?
wrote:wrote:I noticed the resolutions in JK top out at 2048x1536 (the maximum earlier versions of DirectX allowed) with dgvoodoo but if I use WineD3D even the Downsampling resolutions I set up are available. Any chance support for higher resolutions can be added?
Any news?
I fixed '320x200 x-mode only' resolution problem in WIP9, but there is no 2048x1536 limit in dgVoodoo for resolutions.
All of them is enumerated that are coming from DX11. Do you get the missing resolutions in other DX11 games?
Ok, I fixed it, nice find, thanks! It indeed failed silently when blitting from a surface to itself with that flag.
Now the menu works as expected.
