I got some stuff from Ukraine today 😀
The first two packages from Ukraine slipped through the net, the package with battery holders, simm sockets and other stuff from the US aaaand A diddnt.
The hosting site Im using is moving to new servers today, thats why the images loads slowly. It should be solved tomorrow, I also uploaded larger versions hosted here on Vogons.
PC Chips M209 286 board with a Harris 20 MHz CPU, a 10 MHz Intel 287 FPU and 1MB memory.
The board has corrosion damage and the area around the battery was covered in nasty goo, even the BIOS chips have corrosion on their legs.
I cleaned up the area temporarily with some vinegar and White Gas. I need to replace the battery and remove the BIOS chips for cleaning later.
Did the board post? Yes it did 😀 I have not done any more testing yet.
I did also get this Lucky Star LS486E Rev C1 Socket 3 board today, I have not had time to test it yet.
Larger images!
The attachment PC_Chips_M209_large.JPG is no longer available
The attachment Corrosion_large.JPG is no longer available
The attachment better_large.JPG is no longer available
The attachment MSI_LS486E_revC1_large.JPG is no longer available
edit MSI ---> Lucky Star
