Reply 8860 of 60008, by brassicGamer
RacoonRider wrote:
It first appeared long before P4, take a look at this baby:
That is a thing of beauty. Look how clean it is! Ok my new mission in life is to have all my PCBs looking like this.
Reply 8861 of 60008, by RacoonRider
It's the fith or the sixth time I show this picture here, but still:
It's not hard at all! All it takes is some warm water, a wide paintbrush and a piece of soap 😀
Reply 8862 of 60008, by Living
Reply 8863 of 60008, by tincup
RacoonRider wrote:
...It's not hard at all! All it takes is some warm water, a wide paintbrush and a piece of soap 😀
Do you make a final rinse in rubbing alcohol to dilute the water or just let the water dry by itself?
Reply 8864 of 60008, by HighTreason
RacoonRider wrote:
It's the fith or the sixth time I show this picture here, but still: https://dl.dropboxusercontent.com/u/99196890/vogons/P101037 […]
Funny, just a couple of days back I did this;
Reply 8865 of 60008, by Kodai
Nothing wrong with a basic soap and warm water bath for most electronics, but make sure to use distilled water for final rinse. Regular tap water can leave trace elements that over time (say several years), may foul up exposed copper traces and tin plating on the circuits and solder joints.
Reply 8866 of 60008, by HighTreason
Yeah, of swill it down with this;
http://www.houseofswan.com/Media/Default/Prod … ter-fluid-2.jpg
Just make sure the area is well ventilated. I usually wait though, first drying the connector and lightly applying Brasso (Do not press the wadding because it will life the gold!) before waiting a few minutes and rinsing with the petrol.
Reply 8867 of 60008, by boxpressed
Picked this up at a thrift yesterday. I need an ATX case for a build, and I never see standard, non-proprietary cases at thrifts, just an occasional Dell Dimension or Optiplex. This one has a few bumps and bruises, but no major problems. (Side panel is there -- just took it off for installation.) It was very dusty (still haven't cleaned it fully), and there was stuff rattling around when I picked it up. The screws weren't too tight, so I could remove them without a tool in the store. Turns out that the ratting noise came from a GF 6200 that had come out of its AGP slot. The MB is an Asrock K7S41GX. I didn't have time to research it before I bought it, but I was happy to discover it is a Socket 462 board. So, even if nothing was working (and there was a decent chance of that given the dust and disrepair), the case was worth the $10. If the 40GB HD was working, I could use another IDE drive too for another build.
Turns out everything works fine. The cheapo PS made me a little nervous (L&C Computer Co.), but it seems to be running smoothly. Even has a -5v rail. 2 GB PC3200 memory. Duron 1600. With a BIOS flash, I can go as high as an Athlon XP 3200+. The OS was XP Home, so I loaded 98SE, and Asrock has the drivers right on their website. All in all, a nice little micro ATX board for a fast 98SE system, if you don't need ISA.
Reply 8868 of 60008, by Skyscraper
I got some stuff from Ukraine today 😀
The first two packages from Ukraine slipped through the net, the package with battery holders, simm sockets and other stuff from the US aaaand A diddnt.
The hosting site Im using is moving to new servers today, thats why the images loads slowly. It should be solved tomorrow, I also uploaded larger versions hosted here on Vogons.
PC Chips M209 286 board with a Harris 20 MHz CPU, a 10 MHz Intel 287 FPU and 1MB memory.
The board has corrosion damage and the area around the battery was covered in nasty goo, even the BIOS chips have corrosion on their legs.
I cleaned up the area temporarily with some vinegar and White Gas. I need to replace the battery and remove the BIOS chips for cleaning later.
Did the board post? Yes it did 😀 I have not done any more testing yet.
I did also get this Lucky Star LS486E Rev C1 Socket 3 board today, I have not had time to test it yet.
Larger images!
The attachment PC_Chips_M209_large.JPG is no longer available
The attachment Corrosion_large.JPG is no longer available
The attachment better_large.JPG is no longer available
The attachment MSI_LS486E_revC1_large.JPG is no longer available
edit MSI ---> Lucky Star
Reply 8869 of 60008, by Marquzz
Got these in the mail today 😀
Reply 8870 of 60008, by brassicGamer
Hats off to you, sir.
Reply 8871 of 60008, by tincup
Yeah, I rinse delicate stuff in distilled water - but I was curious if "alcohol was involved". I revived a cell phone from a dip in the ocean by first thoroughly submerging and shaking it around in tap water, then repeated with distilled water, then finally alcohol - which basically dilutes the water to nothing then evaporates.
I like that bar soap is used, I was getting tired of seeing Scrubbing Bubbles pictured all the time 😀
Reply 8872 of 60008, by HighTreason
That does it, I'm Coal Tar Soaping the next one so it smells good as well as looks good... Yeah, I'm one of those people who actually like the smell of Coal Tar.
Reply 8873 of 60008, by Imperious
That's a LUCKY STAR motherboard, not MSI. I have the revision "d" version, it is a very good performer Like mine it probably has an Award bios with the Y2K bug, just set the year
to 1998 and the days and month will be correct. No bios flash possible as it probably has a non flashable eprom like mine. I used Bios Patcher to update the Bios then burned my
own Eprom with a 27c010, works fine but to be honest, didn't notice any differences.
Reply 8874 of 60008, by Skyscraper
You are correct, I was tired yesterday evening 😀
Im hoping it will be a decent board, It should support up to 66 MHz FSB and a PCI divider for some overclocking fun. I will test it with a DX4 100 later this week, I also have an AMD 5x86p75 but im not 100% sure if it works or not as the board I got it with was dead as a doornail.
Reply 8875 of 60008, by keropi
I received these cards today:
- an old 16-bit lan card , doubt I'll ever use it:
- an 8bit CGA (I think) + lpt card:
- an 8bit IDE controller , the most interesting thing in the lot 😊
Had to peel off the sticker in the BIOS to see what it was so I could read it (Greek shop put a sticker in the bios, it reads: "Warning , destroying the security tape nullifies guarantee")
So the BIOS has this string at the top: "AT-BUS IDE HARD DISK DRIVE INTERFACE ADAPTER IN XT, VERSION 1.0 Copyright 1990, 1991 JUKO"
So the search led me here: http://www.cyberdelix.net/tech/d16-x.htm and here: http://www.vintage-computer.com/vcforum/showt … ller-Juko-D16-X
also this site here: http://www.minuszerodegrees.net/rom/rom.htm holds a v1.2 image of the bios , though I am not sure it will work with my card since apparently there is also another newer version floating around
I wonder if this controller can work with a CF or if it's any good at all , I will test and report back later...
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 8876 of 60008, by tayyare
Brasso is abrasive, lighter fluid Is harmful to some sort of plastics.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 8877 of 60008, by tayyare
keropi wrote:
.... - an 8bit CGA (I think) + lpt card:....
As far as I know, if there is a LPT port, it most probably be a MDA or Hercules card.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 8878 of 60008, by keropi
^ you are probably right, it must be what you say
Reply 8879 of 60008, by sf78
Went to this old house that was being emptied with a permission to "take what you want". I ended up with this interesting lot. Pentium, Pentium II and a 486/50 plus other related junk. Pentium II had a Voodoo 3 AGP and the 486 had a S3 805 VLB.
