First post, by torindkflt
I know that regularly powering up vintage computers can help preserve them, especially when it comes to the mechanical aspects like hard drives. This is the most commonly cited means of preventing the dreaded "stiction" problem. Unfortunately, I have a Seagate ST-250R (Identical mechanism to the ST-225) with stiction so severe that leaving it sit powered off for more than just a few hours at a time causes it to seize up. As it is right now, the only way to keep this particular drive from seizing under stiction is to leave it powered on continuously 24/7, which is not desirable to me.
I was wondering if there's anything I can do to provide a more long-term solution to preventing the stiction, as well as more "gentle" means of undoing it when it does occur. I don't feel comfortable jerking the drive around to get it to spin up while it is removed, nor do I feel comfortable repeatedly power-cycling the computer to hopefully kick the drive loose while it is installed. I'm not very hopeful, but I thought I'd ask for any other advice.
