First post, by torindkflt
I know that regularly powering up vintage computers can help preserve them, especially when it comes to the mechanical aspects like hard drives. This is the most commonly cited means of preventing the dreaded "stiction" problem. Unfortunately, I have a Seagate ST-250R (Identical mechanism to the ST-225) with stiction so severe that leaving it sit powered off for more than just a few hours at a time causes it to seize up. As it is right now, the only way to keep this particular drive from seizing under stiction is to leave it powered on continuously 24/7, which is not desirable to me.
I was wondering if there's anything I can do to provide a more long-term solution to preventing the stiction, as well as more "gentle" means of undoing it when it does occur. I don't feel comfortable jerking the drive around to get it to spin up while it is removed, nor do I feel comfortable repeatedly power-cycling the computer to hopefully kick the drive loose while it is installed. I'm not very hopeful, but I thought I'd ask for any other advice.
Reply 1 of 6, by ratfink
What are the symptoms of stiction?
Reply 2 of 6, by torindkflt
The drive won't spin up. It's not a lubrication issue with the spindle motor, the read/write heads are physically stuck to the platters. I don't know the technical details behind what ultimately causes this to occur, just that it's a very common problem with old drives from the 80s-early 90s that park their heads on the platters at power down. Repeatedly power-cycling the drive or physically removing it and giving it a swift rotational twist will usually break it loose and allow it to spin up, but this is often only temporary as the heads will once again stick to the platters if the drive is left unpowered for any appreciable length of time. MFM and RLL drives tend to be the most impacted by stiction, but I have an IDE drive from the late 80s that also has symptoms of stiction.
Reply 3 of 6, by PeterLI
I throw/threw them out. No more aggrevation.
Reply 4 of 6, by alexanrs
Maybe it is a lubrication issue with the platter itself. Maybe if you clear the platter and then add another lubricant it will work. Or you'll just finish killing the drive.
Reply 5 of 6, by torindkflt
Did some brief research, and your right, it definitely does appear to be a breakdown of the lubricant coating on the platters that ultimately causes stiction. I would be extremely hesitant to do anything directly to the platters themselves though, so I may just have to call this drive a loss. 😵
Reply 6 of 6, by squareguy
hmmm, well if the drive is a loss anyways... you could build a small clean air box to disassemble the hard drive in and try something. Put it back together and use it. That 'something' is the tricky part. I would personally use something like DeOxit applied to a brand new microfibre lint free cloth used for glasse and gently wipe the platters. It isn't perfect and it might kill the drive but I would try it to see. The DeOxit leaves behind a very thin film of lubrication. I would only try it as a last resort before tossing drive, if it works it could help others too.
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
