First post, by Jiri
I would like to change a default configuration in VDMSound wizard so low-level CD-ROM support would be enabled by default. How can I change that setting? It seems that defaults are not not stored in Windows registry or in .ini file. Some modification of source code should be a way, but (not being a programmer) I do not know, what should I change.
