First post, by Jiri
I would like to change a default configuration in VDMSound wizard so low-level CD-ROM support would be enabled by default. How can I change that setting? It seems that defaults are not not stored in Windows registry or in .ini file. Some modification of source code should be a way, but (not being a programmer) I do not know, what should I change.
Reply 1 of 2, by Reckless
Create a template shortcut and then use the 'Setup a custom configuration' -> 'Reuse existing...' steps.
HTH!
Reply 2 of 2, by Jiri
Thanks. I knew about it, but it is still several more steps:
- set up a custom config
- next
- reuse an existing config
- browse (and navigating to directory)
- open shortcut
- next
- next again
- finish
With changed default would be:
- use a default
- next
- finish
Not a big problem, but if defaults change was possible I would welcome it.
