First post, by theelf
- Oldbie
I found a nice native 640x480 TFT TV, that support from 50 to 75hz
I have a laptop with a nvidia 8600m. In desktop i select 640x480 70hz, and configure dosbox to use desktop resolution, and fulldouble=false
i get perfect sync in games that are 320x200 70hz, exactly like my real DOS PC
Same config with a desktop PC, that have a ATI 4350, and NO way to have a perfect sync, i tried a lot of things, no luck
Two questions
1 - Any advice what is the problem with the ati card? i tried different driver version, no luck
2 - How i can select the "HZ" in dosbox? specially inside dosbox, my idea is to always use 640x480x70hz, and make batch files for games that use diferent refresh than 70hz
Thanks
