Retro Rig Photo Thread
Reply 960 of 3328, by paulo_becas
retrofanatic wrote:
Welcome and very nice build! I have to ask...do you have any compatibility problems with any dos games having that much ram installed?
For now i don't have any problems with games but i experienced a few issues with apps such as PCTools and IE, i can't install this one, it says that i need, at least, 4mb of ram and it just won't install, i guess it just don't like so much memory.
I have only two memory slots on this motherboard with a 64mb and a 32 mb simm, right now i'm considering changing the 64 mb simm for a 32mb and see what happens.
retrofanatic wrote:
I really like that unique case you have there too. Don't see too many like that where the drive bays are at the bottom. Also I like the dual 1.44 floppy drives. Don't see that often either. I love redundancy 🤣.
This is a very unusual case and a small one too, i had to make a few adjustments inside to be able to have three hds in it but overall it quite nice.
I don't have space for a 5 1/4 floppy drive though 😢
AMD Am486/Am5x86-P75 DX5 133 Mhz-64Mb Ram
S3 Trio 64V2DX 2 Mb
Soundblaster AWE64 Gold+Music Quest+MT-32+MU80
LAN-3Com
1.44 3,5 Epson Drive+1.2 5,25 Mitsumi drive+Iomega Zip 256Mb
8gb HDD,4Gb CF HDD
HP CDRW 9200
http://jp-retro.blogspot.com
Reply 961 of 3328, by retrofanatic
Might be a good idea ...96mb is a bit overkill but to each his own. Whatever works for you. I also had some issues with some old application programs when I was running more than 32mb in an older socket 7 build of mine. Hard to say exactly what memory sensitive dos programs and games I have run into but I can say it's always been more when I had over 32mb installed and sometimes even when I've had more than 16mb installed. That's why I like to have separate builds for each era of operating systems but if you need to go with just one build for early windows and dos I think 32mb is enough for most earlier games and programs.
Reply 962 of 3328, by paulo_becas
I agree, i think 32mb is more than enough but since i have a few simms left, i just use them, i'm the kind of person that don't like to have things lying around and not giving use to them (this happens a lot) 😵
Initially i had 2 x 16mb simms, then i swap one for a 32mb and end up with 48mb then another 32mb simm, total 64mb and a few months ago i get my hands on a 64mb simm, and i thought... well... why not... conclusion... not... i just notice that i can't install simtower on winodws because it says that i need true type fonts and it seems that this is a memory issue... it's a ussue alright because i use to play this one a lot in the same pc...
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 963 of 3328, by paulo_becas
As promised here are the inside of my machine 😀
The attachment _DSC0001.JPG is no longer available
My soundblaster AWE64...
The attachment _DSC0002 (2).JPG is no longer available
Matrox Mystique and 3Com Lan card...
The attachment _DSC0004.JPG is no longer available
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 964 of 3328, by oerk
So, it's pretty much an AT minitower upside down... interesting.
Reply 965 of 3328, by retrofanatic
@paulo_becas - very cool. You can also try to incorporate some sort of custom bracket to the upper portion of the case to put the hdd there to free up an external bay, but it still looks very good the way it is.
Reply 966 of 3328, by paulo_becas
I already did that, if you notice the upper bracket with the HD on, it's custom, i've got it from a case i had lying around i only have to made a few holes for it to fit there, i could put another HD on it but i had to remove the hd drawer and, at this time, i just don't feel the need for it.
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 967 of 3328, by retrofanatic
Oh right. I see it now. It looked stock to me at first 🤣..nice job on the that.
Reply 968 of 3328, by King_Corduroy
Sutekh94 wrote:
For a second I thought that case was positioned upside down! 🤣 Anyways, welcome to VOGONS!
I thought the exact same thing, I was confused as shit. 🤣
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 969 of 3328, by manbearpig
The reason most cases aren't oriented like that is because heat rises and the PSU fan exhausts the heat from the top of the case. So unless there is some kind of ventilation in the top of that case, the overall inside temperature is probably higher than a typical-style case.
I have to admit that it is interesting though.
Premio 212B motherboard (MSI MS-6112)
Intel PentiumII 333MHz Slot 1 66MHz bus
384MB ECC 66MHz
SIIG ATA133 controller --> Seagate Barracuda 80GB
SIIG Gigabit Ethernet (RTL8169) / USB 2.0 / IEEE1394 controller
ESS 1869 soundcard on board wavetable synth
Reply 970 of 3328, by dave343
My retro P75 rig running Windows 95 OSR 2.5
Pentium 75
Asus TX97-E w/USB header
32mb EDO
S3 Trio64/V2-DX PCI 2MB
Creativelabs SB16 CT2940 ISA
2.5GB Quantum Bigfoot 5'1/4
40x CD
Dual 1.44 Floppies
14" KDS CRT
US Robotics 33.6 External modem for old school BBS dialing.
Reply 971 of 3328, by loktar
dave343 wrote:
My retro P75 rig running Windows 95 OSR 2.5 […]
Pentium 75
32mb EDO
40x CD
Dual 1.44 Floppies
14" KDS CRT
Looks so neat and tidy. Love the form factor as well!
Reply 972 of 3328, by NightSprinter
The attachment IMG_20151217_201023.jpg is no longer available
Here's the inside of my Win98/DOS box. Thanks to philscomputerlab and some followers I have on Twitch for inspiring me to get back to a dedicated platform for this (meaning I need ti save up for the Magewell/Timeleak card, as the followers wanna see DOS games from real hardware). This system is pretty sweet so far, but can always use improvements.
Specs:
Intel Pentium III-500 Katmai core
256MB PC-100 memory
Intel Seattle SEA440-BX motherboard
ASUS Geforce4 MX420 64MB card (NOT VBE-compliant..)
Creative 3D Blaster2 Voodoo2 12MB
Linksys LNE100TX Fast Ethernet
Turtle Beach Montego-II (AU8830)
Sound Blaster 16 (CT2290)
Gravis UltraSound PnP Pro.
Antec EarthWatts 400
Antec ONE case
Please forgive the clutter in the case.
Reply 973 of 3328, by ElBrunzy
I'm so sad I burned an amiga1200 lately that I'll post the junk here : dead_amiga1200.jpg
Reply 974 of 3328, by rein_ein
Well for now this is only retro rig im using atm.
It acts as my local file server,music box and retro game station ofc 😀
Specs:
mobo - Fic SD11
cpu - Athlon Classic 550mhz Pluto core not OC'ed(got 700mhz Orion but it not stable even at default clock.. workin on it)
ram - 768mb of M.tec SDRAm
sound - Audigy1 sb0090
video - Gigabyte GF FX5900xt
an intel PRO/1000MT for lan
storage 1 - IDE 10.2gb ST310211A for system only
storage 2 - SCSI 147gb Fujitsu MAT3147NP for files and games
an Tekram DC-395U/UW and TR-824 for storage management and hdd tests
os - running xp pro sp2 😒
not all time-matched but i wanted to max it out as possible 🤣
in plans making an middle/high-end p4 and p3 rigs
Reply 975 of 3328, by gdjacobs
This is a really interesting early Athlon build. It could be made into a good match for systems of the day simply by switching to Win98 and using a more period appropriate video card (GF 256, Matrox G400, TNT2). Any interest in going that direction?
Reply 976 of 3328, by rein_ein
Yep interested,got both version of GF 256(ddr and sdr) matrox too,license copy of win98 incoming lately (got one at work,but i'm waiting them to write off it)
Reply 977 of 3328, by mwdmeyer
One of my machines that I used recently in my retro lan.
Pentium 3 500MHz
384MB Ram
Voodoo 4 4500 AGP (Powercolor model)
Windows 98
The attachment IMG_5509.jpg is no longer available
Reply 978 of 3328, by ScoutPilot19
Read somewhere in this thread something like "let's post more 286-386 systems here"- so decided to post pictures of my 286 machines...
Here's IBM AT 5170 with original EGA video-card and a CGA/EGA monitor -
IBM AT 5170 with an VGA monitor connected -
Other 16 and 20 mhz 286'...
Reply 979 of 3328, by Sutekh94
Those are some nice systems 😎
My YouTube | My DeviantArt
