First post, by DAVE86
Hi!
My FIC-486-VIP-IO is missing the VRM module. Placing the parts should not be a problem. I already prepared the vias for the through hole compnents. All I need is the resitor values on positions R86, R87, R89, R92, R93, R113. Luckily the active components part numbers are silkscreened on the board. If someone could list the values or post a high resolution picture of that area I would appreciate it!
191.38 KiB
Thanks!
David
Reply 2 of 3, by kanecvr
I have two 486-vip-io but not on hand (they are in storage). Unfortunately the only pictures of the VRM area I have are quite blurry so they will be no help. PM brostein or hightreason. One of them should be able to help.
