First post, by Unregistered
Hi, I was reffered to this site by a tech. help comp. website, The problem being is that i am trying to get vdmsound to work. I have downloaded v2.0.3 which comes with the extension of an .msi file, I typed .msi into a search engine and found the program for opening msi files. ( microsoft installer if iam correct? ) i downloaded the right version for my required need ( windows 2000 nt ) only to find when installing an error that says
"The windows installer device cannot update the system file c:\winnt\system32\msi.dll because the file is protected by windows,. You may need to update your operating system for this program to work correctly".
So, as you can see, i havent even had a try at installing vdmsound. msinstaller does not seem to work. Any help/advice?
Reply 1 of 3, by Snover
Problem Number One: The latest version is 2.0.4.
Problem Number Two: If MSI didn't come preinstalled with Windows, you need to reinstall your OS, as something has been corrupted in the process.
Yes, it’s my fault.
Reply 2 of 3, by vladr
Yeah, please make sure to download v2.0.4 since it has better compatibility as well as joystick and AdLib support.
Save the .msi file on your harddisk and double-click on it. Windows 2000 and XP come preinstalled with Windows installer.
V.
