First post, by Unregistered
Hi, I was reffered to this site by a tech. help comp. website, The problem being is that i am trying to get vdmsound to work. I have downloaded v2.0.3 which comes with the extension of an .msi file, I typed .msi into a search engine and found the program for opening msi files. ( microsoft installer if iam correct? ) i downloaded the right version for my required need ( windows 2000 nt ) only to find when installing an error that says
"The windows installer device cannot update the system file c:\winnt\system32\msi.dll because the file is protected by windows,. You may need to update your operating system for this program to work correctly".
So, as you can see, i havent even had a try at installing vdmsound. msinstaller does not seem to work. Any help/advice?
