First post, by emosun
Some of them have chips on them , and some have no chips at all. Some are a solid pcb , some have a ribbon.
In order for this to work on any motherboard , all the boards current pci slots would have to be connected to each other in parallel I imagine.
So I flipped a couple boards over and yeah , for the most part the regular pci slots look like they are all connected parallel with each other. Although according to wikipedia many of the pins are not parallel , so I wonder how this card gets around that. Maybe only the chipped cards can relay the data.
So I'm wondering if these work. How they work. Or , are they supposed to be inserted into proprietary slots that happen to use a pci connector.
Reply 1 of 3, by alexanrs
You probably cannot use cards that need bus mastering (at least not two of them), but other than that it should work.
Reply 2 of 3, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Signals that are not shared across PCI slots are configuration space, interrupt and bus master related.
Configuration space: This is absolutely important, thus some logic must exist to turn the two slots into a multifunction PCI device (from the mainboard side of view).
Interrupt: A PCI slot typically gets 4 interrupt lines, and sharing is also possible. They can be distributed between the two cards.
Bus mastering: A mechanism is described to have bus mastering on multifunction devices: https://books.google.de/books?id=tbIvDKSZbR0C … unction&f=false
It probably needs some additional logic too.
So with adapters without any chips I would be sceptical.
1+1=10
