First post, by emosun
- Oldbie
Some of them have chips on them , and some have no chips at all. Some are a solid pcb , some have a ribbon.
In order for this to work on any motherboard , all the boards current pci slots would have to be connected to each other in parallel I imagine.
So I flipped a couple boards over and yeah , for the most part the regular pci slots look like they are all connected parallel with each other. Although according to wikipedia many of the pins are not parallel , so I wonder how this card gets around that. Maybe only the chipped cards can relay the data.
So I'm wondering if these work. How they work. Or , are they supposed to be inserted into proprietary slots that happen to use a pci connector.
