First post, by craigtb
I have a 64-bit Windows 8.1 computer that DOSBOX works on as expected. The legacy DOS application loads and works as it did on my 32-bit Windows 7 system.
I just hooked up a new Windows 7 that is 64-bit but DOSBOX does not work. When I type the command, 'mount c c:\test', for example, I get a response that says that c:\test does not exist.
I can't figure out what makes the critical difference between the two computers.
I even uninstalled DOSBOX and then reinstalled it, but that did not help.
Reply 1 of 7, by leileilol
Obviously, C:\test does not exist. This is not a dosbox problem.
Reply 2 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Please take your time and read the different forum descriptions. Dosbox topics belong in the dosbox forums. Moved it for you now
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 7, by craigtb
Leileilol, the folder does indeed exist. It shows in Windows Explorer as a subdirectory of c:\ and at a DOS prompt, typing 'cd c:\test' takes me directly to that directory.
Reply 5 of 7, by craigtb
it seems to be something more basic than that.
I have even tried 'mount c c:\' and it says that C:\ doesn't exist
Reply 7 of 7, by craigtb
We can end this topic. Sorry for troubling each of you.
I found the problem. The left Shift key on the new keyboard does not work, so I was not typing a colon when I thought I was.
