Reply 20 of 38, by leileilol
DOSBox is fast, it's you that needs a computer upgrade........ and probably a dosbox upgrade
Reply 21 of 38, by DracoNihil
Still wondering if there's any way to getting a Intel HD Audio driver for MSS\AIL or if a TSR to "emulate" a SB16 is feasible...
― Κυνικός Δράκων
Reply 22 of 38, by RaVeN-05
okay leileilol explain why in dosbox i never get runtime error 200? i guess that means dosbox is not working at high cpu Hz values, it emulates low machines, while NTVDM uses high cpu Hz values, probably the same as actual(real) cpu.
so why i need super tractor to run tetris? loool, fool.
DosBox is very good for compatibility but not for speed, its slow, because it emulates cpu on os, while NTVDM probably emulates dos and runs direclty on hardware.
So its just guesses, if you are proffesionals here, okay, than just explain me how i can run chasm in windows xp while i can run games released in 2012 year, i dont need upgrade because i hate new games but i can run them too in my PC. so pros explain me this phenomen??????????????
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 23 of 38, by RaVeN-05
leileilol wrote:
Quake has no vsync and the game timer can exceed 70fps on stock dos quake. You'll have to compensate with huge resolutions, which 1280x1024 is the max, and will still be too fast most likely.
quake runs in dos using athlon 64x2 at 2,6 Ghz in 320x200 resolution without any problems you mention, i guess should work in intel i7 too, i can run at max resolution ant is works great no slowdowns
Reply 24 of 38, by leileilol
because you never have cycles=max in your config, or your dosbox is so old it predates the addition of cycles=auto (and possibly the dynamic recompiler).
Reply 25 of 38, by RaVeN-05
i have max cycles in my config i even press ctrl+f12 to make 105% my dosbox is 0.74 i dont think newer versions have adventage,
the truth is :
http://www.dosbox.com/wiki/Performance (there is test app http://web.archive.org/web/20060201052402/htt … IL/speedtst.zip )
in dosbox i can get 357 mHz cpu
if i run this app in WinXP it reports me 2601 mHz cpu (so NTVDM win here)
Please recommend me some special dosbox build and/or special cfg where i can get maximum mHz cpu)
P.S. I like you leileilol, you awesome person =)!!!! its 100% truth =)
Reply 26 of 38, by leileilol
Every instruction in dosbox is 1 cycle, 357mhz is false. So you need a computer upgrade
(btw speedtst in dosbox reports a "3850mhz" here, if you like to believe in meaningless theoretical clock speed)
Reply 27 of 38, by Azarien
Could a TSR provide SB16 emulation?
Yes, with issues. I remember Sound Blaster Live! had a TSR for emulation of older Sound Blasters.
In some games it worked, in some it did not. And of course it took conventional memory, which is always precious.
And before Live, Gravis Ultrasound also had such a TSR called SBOS, which sometimes even worked.
The only program that could use SBLive natively was said Mpxplay (under plain DOS only, not even Win9x)
It's not that modern soundcards cannot be used under DOS (they can, as mpxplay shows), it's just that new cards aren't compatible with old Sound Blasters (they cannot be, you'd need an ISA bus for that)
Reply 28 of 38, by RaVeN-05
so what i need to do exactly?
Reply 30 of 38, by RaVeN-05
i have 546MHz on dosbox, the host CPU is
CPU Intel Pentium T4400 / 2.2 GHz
Number of Cores Dual-Core
Cache L2 - 1 MB
64-bit Computing Yes
Data Bus Speed 800 MHz
Chipset Type Mobile Intel GL40 Express
http://www.cnet.com/products/samsung-r528-15- … 0-gb-hdd/specs/
not enough?
athlon 64 x2 2,6 gHz not enough?
are you insane here?
what processors you have? but i think problems not in CPU in DOSBOX itself
Reply 33 of 38, by DracoNihil
Yeah, MPXPLAY... That's what always made me feel adventurous in hacking a literal digital sound driver for Intel HD Audio under MSS\AIL. Though yeah, conventional memory being a problem for TSR usage but I'm primarily only going to be playing stuff that runs in 32-bit Protected Mode... would I still run into issues there?
― Κυνικός Δράκων
Reply 34 of 38, by Tertz
Speed Test's results are written in XT equivalent. Numbers with MHz is not benchmark itself, it's a try to identify what CPU you are using.
Also Speed Test would not take into account additional sound and SVGA load. Besides some games may to have closer or farther correlation with it. If you have no Runtime 200 issue, then your emulation may to be below P200 for that game. You may compare you CPU emulation speed in my thread in the signature.
Yeh, you both are like yin/yan of same nature.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 35 of 38, by Azarien
That's what always made me feel adventurous in hacking a literal digital sound driver for Intel HD Audio under MSS\AIL. [...] would I still run into issues there?
Who knows? Perhaps no one tried that yet... It's doable in principle, though I cannot guarantee that you won't run into an unsolvable showstopper.
And if normal means fail, modern CPUs have hardware-assisted virtualization (Ring -1), so you could emulate all hardware you need from there, putting whole DOS into a virtual machine. But that would be a lot of work.
Reply 36 of 38, by DracoNihil
Speaking of hardware VM's, someone linked me to this really bizarre product, I don't have a link anymore but it was a 16-bit ISA slot to USB. The page I remember being on was rather vague and it seemed like a gimmick to me, could that really drive a SB16 and make it usable? Would a hardware VM beable to directly use that device?
― Κυνικός Δράκων
Reply 37 of 38, by Stiletto
They've been discussed before, I think you're talking about the USB2ISA from ArsTech.
search.php?keywords=usb2isa
http://arstech.com/install/ecom-prodshow/usb2isar.html
They're not cheap.
do the Fandango!" - Queen
Stiletto
Reply 38 of 38, by DracoNihil
Yeah, that's the thing. Anybody have any experience with using legacy audio cards with that?
― Κυνικός Δράκων
