First post, by Totempole
I'm extremely tempted to buy a machine with an Intel 815 EP chipset, but not sure if it's really worthwhile. Are there any benefits of an 815EP over a similar configuration 478 such as an MSI 645 or an Intel 845 with backward compatible AGP?
Given that 478 P4 boards cost almost nothing right now, I can't justify spending a significant amount of money on a slower P3 setup.
Since most P4 boards lack support for NMI for Sound Blaster compatibility, I would imagine the P3 setup would be better for that, but my 440BX systems have the DOS segment mostly covered.
So in terms of Windows 98SE 3D accelerated games, would the 815EP have any significant benefits over a 478 P4 with a similar expansion slot configuration?
Thanks in advance.
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
Reply 1 of 5, by PhilsComputerLab
When I built a Windows 98 machine on an even newer chipset, the 865, apart from the lack of AGP support for old cards, I really couldn't find any disadvantages.
If your expansion cards work with a Pentium 4, I agree, you could save quite some money.
YouTube, Facebook, Website
Reply 2 of 5, by Totempole
Well, the SIS 645 for example, and even some Intel 845 motherboards have the same configuration AGP slot as the 815EP.
Having said that, the 815EP system I'm after isn't that expensive. The seller is asking roughly $30. It's got a 1GHz CPU, TNT2 M64 Graphics card and a Sound Blaster CT4830 in it as well.
My Retro Gaming PC:
Gigabyte GA-6BXC
Ensoniq ES1371 PCI
Reply 3 of 5, by nforce4max
Some of those early SIS and VIA P4 boards are 3DFX compatible but in general are pretty poor performance compared to other P4 boards yet still very competitive compared to most P3 builds. If you could get both cheaply it would be best to buy both but seeing how P3 gear is getting to be rare in some parts of the world these days I would go with that.
Reply 4 of 5, by Totempole
I only own one 3DFX card. It's a Voodoo 3 3000. I currently use it in a Socket 370 440BX based board. Would it work any better in an 815EP Motherboard?
A 478 P4 Motherboard and CPU costs under $10 here to give you an idea. I have plenty DDR and PC133 RAM already, so that's not an issue.
My Retro Gaming PC:
Gigabyte GA-6BXC
Ensoniq ES1371 PCI
Reply 5 of 5, by havli
As far as I know, Intel 845 is 1.5V only... so not not compatible with AGP Voodoo3, Riva TNT, some Kyro 2, etc.
On the other hand SiS 645 can run all AGP video cards (in theory at least). One of the not compatible VGAs is Voodoo5 6000 - not a problem for most people I guess. 🤣 General performance is not bad at all. More or less the same as i845 boards or RDRAM based P4 systems.
Most (if not all) SiS 645 boards support FSB 533 with correct AGP and PCI dividers. So usually it is no problem to run P4 2.8 Northwood FSB 533. Asus P4S333 works well even with P4 3.06 (HT not available though).
