First post, by BMOD
Hello,
is it possible to map the decimal point on the numpad instead of a point to comma?
I tried to use the mapper, but I didn't succeed up to now...
On German keyboards you get a comma when you press the decimal point, but even though I configured a German keyboard, I get a point instead.
If using the mapper isn't possible, I am also willing to change the sources of DOSBOX or SDL.
Is the mapping done by the SDL library? I tried to find the corresponding source code, but I wasn't successful.
Can somebody help me?
Many thanks in advance!!
Best regards
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You should be able to use the mapper for that. Click the comma button, then click the "Add" button, then press the period key on the keypad.
Reply 2 of 2, by BMOD
Thanks a lot! I was just too stupid to use the key mapper. I always clicked on the period key and pressed the comma button...
