First post, by BMOD
Hello,
is it possible to map the decimal point on the numpad instead of a point to comma?
I tried to use the mapper, but I didn't succeed up to now...
On German keyboards you get a comma when you press the decimal point, but even though I configured a German keyboard, I get a point instead.
If using the mapper isn't possible, I am also willing to change the sources of DOSBOX or SDL.
Is the mapping done by the SDL library? I tried to find the corresponding source code, but I wasn't successful.
Can somebody help me?
Many thanks in advance!!
Best regards
