Geforce3 Ti 500 vs Geforce 6200
Reply 20 of 96, by AzzKickr
candle_86 wrote:
AzzKickr wrote:
I already found the problem: card was dying. After that benchmark, I turned off the system. Card is now dead sadly 🙁
Well I'd send you mine but I need a replacement first 🤣
Hahah, thx buddy. Appreciate the gesture but I already have my eye on an alternative 😉 (if the oven-bake-trick turns out bad)
Heresy grows from idleness ...
Reply 21 of 96, by matze79
bake oven is no solution, if you do it proper you need desolder the chip, reball it and resolder.
It works short time periods if you just reheat with the bake oven.
Another Method is to apply fluid flux to the BGA so it flows under the Chip, and heat the BGA Chip with a heatgun.
Shield all other components from Heat! Alufoil helps greatly.
Reply 22 of 96, by candle_86
Well my question is now irrelavant my system will be getting a BFG FX 5900 on Monday. Which I know is faster than either card 🤣
Reply 23 of 96, by swaaye
Actually a 6200 would probably win with any pixel shader 2.0 usage. I know a 6600GT usually stomps 5900 Ultra across the board. 😁
Reply 24 of 96, by candle_86
Nah i remember back in 2004 my FX 5900XT died and i could only afford a 6200 NV44 AGP card, i lost preformance in FarCry, Call of Duty and Counter Strike Source
Reply 25 of 96, by swaaye
You need to try Oblivion, FEAR and Half Life 2 (in forced D3D9 mode). I think a 6200 will win. 5900 really chokes on those.
Yeah in simpler games the 5900 Ultra can pull ahead with its fillrate and bandwidth. But it is still somewhere in between a 6200 and 6600.
Reply 26 of 96, by PhilsComputerLab
I think any of these cards will choke on F.E.A.R. 🤣
YouTube, Facebook, Website
Reply 27 of 96, by RacoonRider
Actually, Oblivion is so heavy and unoptimized that there are moments when it almost chokes my HD4870X2 on high. Playing on 9600XT was impossible, and there were moments when x1800GTO sucked on medium. There's no way 6200 or any FX can handle Oblivion 😀 HL2 though would work well, at least Portal runs good on 9800Pro.
[offtopic] Btw, I think that Skyrim runs better than Oblivion on older systems and looks better at the same time [/offtopic]
Reply 28 of 96, by candle_86
I've seen Oblivion choke on an x1900XTX my buddy had back in 2006 running at 1440x900 medium, so I wouldn't even try to run it on 2003 hardware if 2006 hardware can't handle it. It look what the 8800GTX/GTX 280 to make Oblivion actually playable in its glory.
And since most of my games are DX5/DX6/DX7/OpenGL based I will be playing an FX 5900 will make a 6200 cry like a little girl.
The newest game I intend to run on this Machine is Star Trek Elite Force II.
Reply 29 of 96, by PhilsComputerLab
I'd still love to see some benchmark results if possible 😀
Nothing beats a good old head to head...
Reply 30 of 96, by candle_86
sure ill run some next week when i have the Ti 500, FX 5900 and Geforce 6200.
I'll run
3dmark 2000
3dmark 2001 SE
3dmark 2003
Quake 3 Time demo
Doom 3 Time Demo
any other requests?
Reply 31 of 96, by PhilsComputerLab
Maybe a DirectX game?
X2 demo for example. Has a nice benchmark built in.
Reply 32 of 96, by candle_86
ill check out X2, I can also run FarCry Demo on this machine as well as Halo
Reply 33 of 96, by PhilsComputerLab
Perfect!
Reply 34 of 96, by swaaye
Eh a 5900U underperforms a 9600XT in Oblivion by quite a bit. I've run both and I promise a 9600XT can play Oblivion acceptably at 640x480. I have video of the fun I recorded with my 5950 years ago.
https://www.youtube.com/watch?v=qzDZhb808ts
FEAR is the same story. Though I should have run 640x480.
https://www.youtube.com/watch?v=0rlZb6YsJOQ
Here's Half Life 2 D3D8 vs 9.
https://www.youtube.com/watch?v=KwUxxLzu-uk
STALKER in its static lighting mode (D3D8). This interested me because this game started development during NV3x days and was initially advertised with NV3x in mind.
https://www.youtube.com/watch?v=OOneA51UdEo
The problem is any game that uses pixel shader 2 is hopeless even on NV35. FEAR has a D3D8 shader option, HL2 defaults to D3D8 on NV3x, and Oblivion is entirely PS2.0 with some extra 3.0 in some cases.
FarCry runs a mix of D3D8 and 9. The console tells all, I believe. Halo might default to D3D8 with FX but I don't recall anymore.
Reply 35 of 96, by Skyscraper
swaaye wrote:
Eh a 5900U underperforms a 9600XT in Oblivion by quite a bit. I've run both and I promise a 9600XT can play Oblivion acceptably […]
FarCry runs a mix of D3D8 and 9. Halo might default to D3D8 with FX but I don't recall anymore.
I think the point is that noone wants to play games such as these using anything slower than a Geforce 7800 or Radeon X1900 so it dosnt matter if the FX5900 is slower than a donut running pixel shader 2 stuff. 640*480 or 800*600 does't cut it, at least not for me.
The FX5900 kicks ass running DX7 and DX8! 😀
Reply 36 of 96, by swaaye
Skyscraper wrote:
I think the point is that noone wants to play these games using anything slower than a Geforce 7800 or Radeon X1900 so it dosnt matter if the FX5900 is slower than a donut in these games. 640*480 does't cut it, at least not for me.
Well duh. The implication was 5900 U being faster than 6200. Not always the case. I'm also not sure it's a kick ass D3D8 card but hey whatever. It's a bit faster than a Ti 4600 and that's about it.
Reply 37 of 96, by Skyscraper
Well it's faster when it comes to everything that matters.
Reply 38 of 96, by swaaye
Oh ok. Thanks for your assistance with the obvious then.
Reply 39 of 96, by Skyscraper
You are welcome.
