Bought this (Modern) hardware today
Reply 140 of 2327, by kithylin
Munx wrote:
Got this baby today to replace the stock AMD cooler on my fx.
Idle temps went from ~22C to ~12C, plus my PC no longer sounds like a jet engine 😎
The 212 is legendary as one of the best PC coolers around. Nice choice. 😀
Reply 141 of 2327, by mrau
@munx what cpu/wattage is that? i have a 125W FX 6200 3.8 and i now easily hit 70C under load; im probably going for the
FORTIS 3 HE1425 or even the GRANDIS XE1236 but im not entirely sure this will solve the problem as my GPU likes
to cross 70C under load as well
Reply 142 of 2327, by Munx
FX6100. On stock cooling I dont think Ive ever seen it go past the 65C mark even under a gaming load until recently.
It could be the questionable stock thermal paste they give, mine was almost crust after less than 3 years.
My builds!
The Underdog - The budget K6
Reply 143 of 2327, by mmx_91
Nice!! I have the same cooler, but mounted in another heatsink (CM Geminii M4, which is the flat/compact model) and love it!! CPUs work really cool with one of those 212 😀
Reply 144 of 2327, by Robin4
havli wrote:
Gigabyte GA-P55-UD4P […]
This particular board is a pre production revision (see rev 0.1 in the top left corner), probably meant for (p)reviews. This one looks slightly different from regular UD4P - old heatsink design which was used on some 1366 and AM2 boards. And next to IDE apparently there was supposed to be located some weird I/O connector, maybe sata express. http://www.gigabyte.com/products/product-page … spx?pid=3160#ov
Well, the hard part is this board has very old bios and supposedly it is not possible to update it. So I must get i5 750 which is the oldest 1156 CPU and hope for the best (I'm not even sure the board works).
really like to know why you cant update the bios?
It doesnt seems to be that hard?
http://www.gigabyte.com/products/product-page … x?pid=3160#bios
Reply 145 of 2327, by havli
This board is pre-production revision and I was told by the previous owner that regular BIOS update is not possible.
My intention is to run i5 750... and that one should work regardless of BIOS version. 1156 boards are quite expensive here and I'm not going to try my luck... and possibly brick it by unnecessary update. 😵
Reply 146 of 2327, by Jade Falcon
Rank BANNED
BANNED
Best at what? Their cooling is ok at best. But you could not beat the value they had when they first came out.
Reply 147 of 2327, by kithylin
http://www.newegg.com/Product/Product.aspx?It … N82E16835103099
Just have a look at their newegg page. 2800 5-star happy reviews and another 740 at 4-star. It's just.. it may not be class-leading but it's one of the "staples" of just.. pick it and tell someone to use it if they're building a system and need something better than stock, and don't worry about performance and know it will do well for them. They're really great coolers in general.
Reply 148 of 2327, by havli
More CPUs arrived... 😀
2x Xeon X5450... pretty much xeon equivalent of C2Q Q9650, with SMP support of course. Will be interesting to compare these two with 8-core AMD FX. 😈
Xeon W3520 - same as i7 920... but much cheaper. Ebay logic. 😁 And next to it Sempron 140.
Reply 149 of 2327, by brostenen
Bought one of these Google Cardboard things. Need to see what it's all about, and the price is really cheap.
http://www.ebay.com/itm/Virtual-Reality-3D-Vi … vMAAOSwQJhUlX1k
Reply 150 of 2327, by nforce4max
Picked up another Xeon E5 V3 for $104 shipped, some oddball QS model with 12 cores and 30mb of L3 cache. Wanted to try out a V4 Broadwell but too many of them are ES that don't play nice with x99 boards for comfort.
Reply 151 of 2327, by Cyrix200+
Got me this HP Proliant MicroServer Gen8 G1610T to replace my Synology NAS (and to play around with 😀). Now looking for a Xeon CPU to upgrade it with (but hard to find a Socket 1155 Xeon). The Celeron in it now is also quite fast actually!
1982 to 2001
Reply 153 of 2327, by Cyrix200+
Thanks for the links. I'll start with the Celeron and see what I run into.
kithylin wrote:
http://www.ebay.com/sch/i.html?_from=R40&_sac … =p2045573.m1684 […]
Fastest 1155 xeon ever made.
http://www.cpu-world.com/CPUs/Xeon/index.html
Go here, click Socket 1155, then scroll down and see both families. Should help you find a CPU for it.
1982 to 2001
Reply 154 of 2327, by stamasd
Just bought a Lenovo IS6XM motherboard. It was the cheapest socket 1155 motherboard I could find that has enough slots and connectors for my purpose. I have an i7-2600k cpu that has been gathering dust for the past 2 years, since I accidentally messed the pins in the cpu socket of the motherboard it was originally installed in, and didn't have the time/motivation to rebuild that system until now. I want to make a small form computer that will be used as a dedicated game server for ARK: Survival Evolved. With a 4-core 3.4GHz cpu, 16GB of DDR3 and a 250GB SSD it should be able to support a pretty sweet world, tricked with mods and whatnot.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 155 of 2327, by kithylin
I already run an ark evolved server myself in my server in the other room. If you have any questions, PM me and I'd be happy to chat with you and help get it going sometime.
Reply 156 of 2327, by stamasd
Thanks for the offer. I have actually setup a server this morning on a test machine, works very well. Finding the options for the server and the files they should go in was a bit of a challenge but I found all I need (it's a headless Linux installation so I have to do all editing remotely through ssh). I do have a question or two so I'll take it to PM.
I/O, I/O,
I/O, I/O
Reply 157 of 2327, by y2k se
Be careful with the CPU you put in it. The G1610T is a 35W TDP model. Here's HP's spec sheet for the Gen8's.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 158 of 2327, by kithylin
Wow, it only supports dual core cpu's? that's pretty crappy.
Reply 159 of 2327, by y2k se
They are enough for the normal use case on those systems.
