First post, by Kahenraz
What is it? 😐
images?q=tbn:ANd9GcQVulqQvydUwA_5PHo8DAEOTYqUq1d2NVL3PeVXoqBsXQxjWRK_
The closest I can get is an Asus P3V133 but the chipset says AMD. So is it a slot A.. ?
Reply 1 of 11, by Robin4
Its an Slot A indeed. Maybe this board having the AMD 750 irongate chipset.
Reply 2 of 11, by Tetrium
Kahenraz wrote:
What is it? :neutral: […]
What is it? 😐
Looks like a red herring.
But if it's an AMD chipset and the CPU sits in a slot, chances are good it's indeed a Slot A board, lucky you 😀
My retro rigs (old topic)
Report spammers here!
Reply 6 of 11, by SquallStrife
Found this:
http://www.cpu-info.com/index2.php?mainid=athlon
In October 1998 on the Microprocessor Forum, Dirk Meyer gave a presentation about the K7 and its features. He baffled his audience with the top performance specifications of the soon to be released CPU. Unfortunately for his audience he did not show a working system.
Not long after the Microprocessor forum, AMD demonstrated a system based on a 500MHz K7 at the COMDEX in November 1998. Behind closed doors a few people got the opportunity to see AMD's 7th generation CPU in action. The system consisted of the Gomez motherboard with an early sample of the K7. On another tradeshow, the CEBIT in March 1999, AMD showed a 600MHz K7 on the Fester reference motherboard.
Reply 8 of 11, by Tetrium
Would be interesting to see if this ES motherboard is actually stable enough to install Windows, loads of fun! 🤣
Reply 10 of 11, by brassicGamer
stamasd wrote:
The placement of the ATX connector is horrible.
Seems to be a thing with Slot A boards - if your PSU has anything other than a really skinny clip on the ATX connector, some hacking is required to avoid fouling that big capacitor. Never had that problem on any other board.
439.87 KiB
Reply 11 of 11, by candle_86
Here is a SOYO 6BA+ IV
I have this board and you need a precision screwdriver to hit that clip or you mess with the caps
