First post, by TheAbandonwareGuy
- Oldbie
Wow im not having good luck with PC's today. Just figured out why my main PC (Core2Quad for gaming, yes, silly me i know) has been having loading stutters in Fallout 4.
My PNY Optima DDR2 800MHZ memory is running at exactly half speed according to validator (400 instead of 800)
The validator link is in my signature but heres the main system specs.
CPU Name
Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Threading
1 CPU - 4 Core - 4 Thread
Frequency
2493.51 MHz (7.5 * 332.47 MHz)
Multiplier
Current: 7.5 / Min: 6 / Max: 7.5
Architecture
Yorkfield / R0 Step (45 nm)
Cpuid / Ext.
6.7.A / 6.17
IA Extensions
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Caches
L1D : 32 KB / L2 : 2048 KB
Caches Assoc.
L1D : 8-way / L2 : 8-way
Microcode
Rev. 0x00000A0B
TDP / Vcore
95 Watts / 1.25 Volts
Type
Retail (Original Frequency : 2500 MHz)
Motherboard
Model
Dell 0KP561
Socket
Socket 775 LGA
North Bridge
Intel P35/G33/G31 rev 0A
South Bridge
Intel 82801GB (ICH7/R) rev A1
BIOS
Dell Inc. A10 (11/01/2011)
Memory (RAM)
Total Size
4096 MB
Type
Dual Channel (128 bit) DDR2-SDRAM
Frequency
399 MHz - Ratio 5:6
Timings
6-6-6-18-2 (tCAS-tRC-tRP-tRAS-tCR)
Slot #1 Module
PNY Electronics 2048 MB (DDR2-800)
Slot #2 Module
Any obvious reason why the gaming speed DDR2 i paid 50 dollars (I had to get mine new, used wasnt an option for my main rig) for back in early 2015 would be running at half its rated speed? Confused as hell atm.
