First post, by TheAbandonwareGuy
Wow im not having good luck with PC's today. Just figured out why my main PC (Core2Quad for gaming, yes, silly me i know) has been having loading stutters in Fallout 4.
My PNY Optima DDR2 800MHZ memory is running at exactly half speed according to validator (400 instead of 800)
The validator link is in my signature but heres the main system specs.
CPU Name
Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Threading
1 CPU - 4 Core - 4 Thread
Frequency
2493.51 MHz (7.5 * 332.47 MHz)
Multiplier
Current: 7.5 / Min: 6 / Max: 7.5
Architecture
Yorkfield / R0 Step (45 nm)
Cpuid / Ext.
6.7.A / 6.17
IA Extensions
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Caches
L1D : 32 KB / L2 : 2048 KB
Caches Assoc.
L1D : 8-way / L2 : 8-way
Microcode
Rev. 0x00000A0B
TDP / Vcore
95 Watts / 1.25 Volts
Type
Retail (Original Frequency : 2500 MHz)
Motherboard
Model
Dell 0KP561
Socket
Socket 775 LGA
North Bridge
Intel P35/G33/G31 rev 0A
South Bridge
Intel 82801GB (ICH7/R) rev A1
BIOS
Dell Inc. A10 (11/01/2011)
Memory (RAM)
Total Size
4096 MB
Type
Dual Channel (128 bit) DDR2-SDRAM
Frequency
399 MHz - Ratio 5:6
Timings
6-6-6-18-2 (tCAS-tRC-tRP-tRAS-tCR)
Slot #1 Module
PNY Electronics 2048 MB (DDR2-800)
Slot #2 Module
Any obvious reason why the gaming speed DDR2 i paid 50 dollars (I had to get mine new, used wasnt an option for my main rig) for back in early 2015 would be running at half its rated speed? Confused as hell atm.
Reply 1 of 15, by PhilsComputerLab
Doesn't DDR 800 run at 400 MHz?
Reply 2 of 15, by SquallStrife
Winner.
Reply 3 of 15, by TheAbandonwareGuy
Winner.
so DDR2 800 MHZ Doesnt run at 800MHZ?
Reply 4 of 15, by Jade Falcon
Rank BANNED
BANNED
Winner.
That's ddr for you. 800mhz is its evicted clock rate.
https://en.m.wikipedia.org/wiki/Multi-channel … el_architecture
Reply 5 of 15, by TheAbandonwareGuy
Yep, it would seem im an idiot 🤣
Reply 6 of 15, by SquallStrife
That link is about dual-channel DDR, which doubles the effective data rate again. Not the reason that DDR2-800 runs at 400MHz.
OP, the 800 in DDR2-800 is MT/s, not MHz. MT/s is Mega Transfers/second.
Single data rate synchronous DRAM (SDR SDRAM) runs, as the name suggests, synchronously with the CPU's frontside bus. It achieves one transfer per clock, so at 133MHz, you get 133MT/s.
Double data rate SDRAM (DDR SDRAM) doubles the amount of data transferred per clock cycle, by transferring data on both the leading and trailing edges of the clock signal. Thus, with a FSB speed of 133MHz, you get 266MT/s, and hence DDR-266.
Or as in this case, 400MHz yielding 800 MT/s.
Reply 7 of 15, by SRQ
I had the same confusion when I got my DDR3 system together. It's akin to the idiotic megabit/byte thing for hard drives.
Reply 8 of 15, by Anonymous Coward
I always said that DDR was a big marketing scam that only serves to confuse people. CPUs and memory should be advertised at their actual clock rates. HDDs should also be advertised with their actual formatted capacities. None of this 1,000,000 bytes = 1MB bullshit, or how 1GB is defined as 1,000,000 "MBs".
Reply 9 of 15, by noshutdown
hey... doesn't ddr2-800 run with 200mhz clock just like ddr-400? it performs 4 transfers in a clock cycle, therebye 200*4 transfers in a second.
Reply 10 of 15, by stamasd
Um, no. All DDR variants (DDR, DDR2, DDR3 etc) perform 2 transfers per external clock cycle, hence "double data rate". The differences between generations of DDR are minor (timings, prefetch queue depth, higher FSB etc)
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 11 of 15, by PhilsComputerLab
Something I noticed with modern graphics cards. Memory throughput using "compressed" data 😀
Reply 12 of 15, by Jo22
Yup, that reminds of the data rate of analogue modems (baud vs bit/s).
Manufacturers were quite optimistic regarding the actual speed of their modems..
Reply 13 of 15, by Jade Falcon
Rank BANNED
BANNED
SquallStrife wrote:
That link is about dual-channel DDR, which doubles the effective data rate again. Not the reason that DDR2-800 runs at 400MHz. […]
Wops some how I thinker the wrong one. I'll get the right one tonight.
Reply 14 of 15, by SquallStrife
What you're describing is somewhat like QDR SDRAM, though in practice it's a little different than the name suggests.
Reply 15 of 15, by leileilol
It's what I hated about the whole MBits marketing of 16-bit era gaming. 🙁
Debian's fucked
