First post, by bluejeans
I got my first pc in 1998 and I can swear that whatever sound card I was using was much better than opl3, but not as good as wavetable/ms wavetable synth. E.g at the doom 2 title screen, the strings sounded like the Psycho shower scene and the cymbals were much less realistic/almost sounded like they weren't there. I compared a midi being played on this card to someone elses' awe32/64 and his instruments sounded completely realistic. Could it have been a card that tried to do wavetable but wasn't quite up to the task? Or am I just looking through nostalgia goggles? Looking at what drivers I had on cd back then, I owned an avance logic as007 and an analog devices ad1816. I've tried a few ISA cards that I got a few days ago that are sound blaster compatible/opl3 but they sound, well, opl3... and a sb live and creative 128 which basically sound identical to the ms wavetable synth.
Reply 1 of 27, by Scali
How about the Roland MT-32/LAPC-1? https://en.wikipedia.org/wiki/Roland_LAPC-I
https://en.wikipedia.org/wiki/Roland_MT-32
It uses LA synthesis: https://en.wikipedia.org/wiki/Linear_Arithmetic_synthesis
Basically a combination of short wavetable samples (mainly for accurate attack of an instrument, to imply the proper timbre) and subtractive synthesis (for sustaining notes).
Reply 2 of 27, by bluejeans
Scali wrote:
How about the Roland MT-32/LAPC-1? https://en.wikipedia.org/wiki/Roland_LAPC-I https://en.wikipedia.org/wiki/Roland_MT-32 It use […]
I don't recall setting up dos games for anything other than sound blaster. Definitely wasn't the LAPC as that card is huge. Also I remember setting up the majority of games to use sound blaster for both sfx and music.
Reply 3 of 27, by squareguy
I had an ISA sound card in a 1997 gateway 2000 that reminds me of what you mean. A soundblaster 16 was a downgrade. I Vivio maybe
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 4 of 27, by badmojo
Some OPL3 clones don't sound like OPL3, have you tried cards based on the chipsets you have drivers for on the CD? I have a couple of cards with onboard wavetable chipsets, but they're low end and don't sound nearly as good as the better known GM chipsets, could have just been bad GM you're remembering.
But then you'd have had to select General Midi in the game's setup programs, which it doesn't sound like you were doing.
Reply 5 of 27, by F2bnp
Perhaps you were using an Audio PCI or Live! card, some of these map OPL3 to General MIDI, so they tend to sound very wrong and different to OPL3.
Reply 6 of 27, by PhilsComputerLab
I was thinking the same thing 😀
Reply 7 of 27, by bluejeans
I take it they don't exactly advertise this feature? My sb live 5.1 doesn't do it, and I'm guessing an enqoniq would be the audio pci you're thinking of.
Reply 8 of 27, by PhilsComputerLab
Yea it's the Audio PCI. Creative bought Ensoniq and then sold a few cards under various names. Sound Blaster PCI 128 or something like that?
Reply 9 of 27, by bluejeans
I have a 128, sounds almost identical to xp's software synth.
Reply 10 of 27, by PhilsComputerLab
Try a DOS game with Sound Blaster / FM option.
Reply 11 of 27, by bluejeans
From within windows 98 or true dos?
Reply 12 of 27, by gdjacobs
Both.
Reply 13 of 27, by ElBrunzy
I think your thread title say's it all, they where called opl4, a mix of the opl3 and wavetable technologies. Chances are you got an YMF278, I'll crave to listen to one of them!
Reply 14 of 27, by bluejeans
gdjacobs wrote:
Both.
Well, this is what it sounds like in either mode. I had a similar problem with the live under dos, it was due to an incomplete patch set or file or something like that.
https://youtu.be/dU26F3LqgY8
Reply 15 of 27, by PhilsComputerLab
That's it 😀
The AudioPCI simply does not have a FM chip, it "simulates" FM by mapping instruments from the wavetable.
It sounds horrible as a result 🤣
Reply 16 of 27, by bluejeans
That's it 😀
I found an opl4 soundfont and it sounds much better than that.
Reply 17 of 27, by PhilsComputerLab
That's it 😀
Well of course, any SoundFont sounds better than the AudioPCI's FM 😀
Though it makes no sense comparing the two, as the Audio PCI has its own General MIDI support anyway. Just use that instead.
Reply 18 of 27, by bluejeans
That's it 😀
How should its' general midi sound compared to the ms wavetable synth?
Reply 19 of 27, by PhilsComputerLab
How long is a piece of string?
Just got to listen, compare and make up your own mind as it's subjective.
