First post, by GuyTechie
Just got a Asus P3B-F 440BX motherboard from a seller on Ebay. When I boot it up, I get a Hardware Monitor Error. I go into the BIOS and I see a red text for -5V (says it's actually -6.14v).
I'm using a new Corsair CX750M. I tried a different PSU (another CX750M) - same thing.
After some Googling, this guy seems to have the same problem, but was told to just ignore it. That doesn't seem right...
http://www.pcreview.co.uk/threads/p3b-f-bios- … -error.3831759/
Anyone else seen this issue before?
Edit - more details: I got this with the original bios (1004). I also updated to the newest "beta" firmware (1008f). Same thing on both.
Edit - more Googling and I found this:
http://forums.anandtech.com/showthread.php?t=21443
Seems that modern PSUs no longer have a -5V rail, so the hardware monitor freaks out and just displays -6.14v when it's actually floating. I confirmed by looking at the specs of my PSUs.
I'm still not feeling all that good about it. I wonder if I should look for an older PSU. Dang... that sounds like a bad idea as soon as I said it...
It is annoying the motherboard just hangs there until you hit F1 to continue though.
Reply 1 of 6, by luckybob
its fine. -5 was rarely used, save for a choice few sound/midi cards. If you care enough, you can make your own -5v supply rail. Or put a resister fro the -5v line to ground. or just ignore it.
I'd just ignore it, or turn off reporting in bios.
Reply 2 of 6, by archsan
Yeah, I've got something like -13.4567 V myself. No big deal if you aren't using very old sound cards like Roland LAPC-I for example.
Btw, what CPU have you got with it? Tried a 133 FSB one?
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 3 of 6, by GuyTechie
I only have a PII-266 (that came with the mobo) - that uses FSB 66MHz and a PIII-650 - FSB 100 MHz.
What I'm surprised about though is the PII-266 has a small heatsink and fan (retail), but the PIII-650 has a large but passive heatsink. While idling in the BIOS, the CPU temps according to the hardware monitor went up to 68C! I quickly plugged in a 120 mm fan to the CPU fan header and it went down, but the hardware monitor then warned me about the fan speed being too low (1400 RPMs) - I guess doesn't know 120 mm fans doesn't spin all that fast, 🤣.
I have a SB 16 (CT2230) I plan on using. Does that need a -5V rail?
I found out you can set the hardware monitor to ignore certain things including the -5V rail, so I did.
Thanks for the replies!
Reply 4 of 6, by Arctic
I have the same problem. I get freaky voltage readings on my P2B of like +13.6v.
That is why I immediately stopped using it. Could that mean that our boards need new caps?
Because I think my power supply is still fine.
Overvolting your components can (and probably would) damage them.
Reply 5 of 6, by archsan
OK, I've got a 800EB that my board sometimes won't POST with, even though I set it at 6x100 (probably another issue). Though when it has booted successfully 6x133 seems to run just fine afterward. Still I think it's safest to stay with native 100 FSB Coppermine chips.
Nope. The Mystery -5V Rail
Arctic wrote:
I have the same problem. I get freaky voltage readings on my P2B of like +13.6v. That is why I immediately stopped using it. Cou […]
Hmm, what's that +13.6V on? +12V?
Mine only has that random reading on what supposed to be -5V though, the other numbers are fine (the better the PSU the tighter the values of course). Since the board and components don't use -5V there should be no problem, as long as the PSU is good.
Reply 6 of 6, by SPBHM
you can set the bios to ignore the -5v error, that's normal.
I have it on my P2B since I used a newer PSU.
also in general you can't always trust MB reading all that much, you need to measure it with a voltmeter or something.
