First post, by GuyTechie
Just got a Asus P3B-F 440BX motherboard from a seller on Ebay. When I boot it up, I get a Hardware Monitor Error. I go into the BIOS and I see a red text for -5V (says it's actually -6.14v).
I'm using a new Corsair CX750M. I tried a different PSU (another CX750M) - same thing.
After some Googling, this guy seems to have the same problem, but was told to just ignore it. That doesn't seem right...
http://www.pcreview.co.uk/threads/p3b-f-bios- … -error.3831759/
Anyone else seen this issue before?
Edit - more details: I got this with the original bios (1004). I also updated to the newest "beta" firmware (1008f). Same thing on both.
Edit - more Googling and I found this:
http://forums.anandtech.com/showthread.php?t=21443
Seems that modern PSUs no longer have a -5V rail, so the hardware monitor freaks out and just displays -6.14v when it's actually floating. I confirmed by looking at the specs of my PSUs.
I'm still not feeling all that good about it. I wonder if I should look for an older PSU. Dang... that sounds like a bad idea as soon as I said it...
It is annoying the motherboard just hangs there until you hit F1 to continue though.
