That is the first thing I did when I tried to revive an old 486 board a couple of years ago - solder in a coin cell battery holder. So I did, then I put in a cr2032. It worked fine for a couple of days, but then while playing lemmings I herd a loud POP and the computer froze. The CR2032 exploded. I took out my voldmeter and noticed the motherboard was supplying 4.6v to the contacts were the barrel battery was soldered (and where I soldered the coin cell battery holder).
I've seen rechargeable soldered 3.6v coin cell batteries like the one brostenen posted - but be warned - those leak as well - and since one surface is so close to the MB, I consider them more dangerous then barrels. They're also more expensive.
h-a-l-9000 wrote:Please don't suggest the LR2032 as a replacemnet for 3.6V NiCd - the charging voltage of max. 4.2V will be exceeded.
I measured 4v on two boards (Soyo 386 board and gemlight 486 board - even tough the manual specifies 6v) - so it should be safe. It's best to check with a volt-meter to be safe. If it's over 4v, don't use an LR2032.
jesolo wrote:Most motherboards from that era had an external battery connector, but in most cases, it was meant to connect a non rechargeable battery "pack", in the event that the barrel battery stopped
Curious. My gemlight 486sps103 is providing 4v trought pins 1 and 4 of the external battery connector.
@einr -if the board came with an external battery only, you need to use one of those. Generally pin 4 is negative and pin 1 si positive (connect red cable side). Pin 1 should be silk-screened right next to the connector. Try finding a manual online to see if it provides power to the external battery - or better - a volt-meter.
