Lo-tech 1MB ram card Question....
First post, by Megadisk
Hello, I just got done putting together a lo-tech 1Mb ram card and I also have a Sega/IBM 286 Sega Teradrive that I'm trying to figure out if I can somehow use the lo-tech 1MB card with it.
The Teradrive has a base memory of 512Kb, and it also has 2x 30pin simm slots that when fully populated (only supports 1MB per slot) brings the system to 2.5MB which also fills the 512kb to 640Kb.
Any ideas? I'm all ears 😀
Thanks for any replies!
Reply 1 of 22, by bhtooefr
The only way I can see that card being useful on a 286 like that is if you use it to fill in upper memory blocks, and then use third-party tools to load things into those UMBs, freeing up conventional memory elsewhere.
Be aware that the UMB memory would be slower, though.
Reply 2 of 22, by Megadisk
Thanks for the reply!.
How should I set the dip switches to set the 1MB card for UMBs?
Reply 3 of 22, by stamasd
According to the wiki https://www.lo-tech.co.uk/wiki/1MB-RAM-Board you set switches 2.3, 2.4, 2.5, 2.6 and 2.7 to "on"
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 5 of 22, by carlostex
I do not see the use of that card in a 286 system that has simm expansion. Because if the simms can provide the last 128kb of RAM it must provide upper memory blocks as well. All the remaining RAM will be extended meory. Unless the Sega Teradrive works in some weirder way...
Remove the Lo-tech card use HIMEM.SYS and check what MEM reports
Reply 6 of 22, by Megadisk
^ As requested, after a fresh installation of MS-DOS.622 :
Also when it comes to some of the addresses, I've been told the Teradrive uses:
000h-A000h : for 640kb
A000h-C000h: VGA RAM
C000h-D000h-: some more Bios related.
D000h-E000h: EMS
E000h-FFFFh :128kb bios
Reply 7 of 22, by stamasd
Load emm386.exe and see add DOS=UMB to config.sys; see if MEM reports UMBs.
I/O, I/O,
I/O, I/O
Reply 8 of 22, by Jo22
On a 286 machine ? 😳
Reply 9 of 22, by Megadisk
Isn't emm386 for 386 and up pcs?
Edit: Jojo beat me to it 😀
Reply 10 of 22, by stamasd
Oops, my bad.
There are other packages that work for 8088 and up to enable UMBs. e.g. google "use-umbs". Try that and see if it enables any UMBs.
(edit) ftp://ftp.icm.edu.pl/pub/msdos/coast/memutil/use-umbs.zip
I/O, I/O,
I/O, I/O
Reply 11 of 22, by carlostex
If the Teradrive uses all the UMA there's no point in thinking the Lo-Tech card can give you UMB's. All the UMA are is being provided by the RAM sticks.
So the VGA chip doesn't have its own dedicated RAM? Takes 64KB from the UMA? That's laaaaame no wonder that thing is so slow...
Reply 12 of 22, by Megadisk
Very slow indeed 😵
So, there is nothing the 1MB card can do?
I also tried the Lo-tech 2MB EMS card, it works but keeps locking up.
Reply 13 of 22, by carlostex
Lo tech 1MB RAM cards are awesome in an XT.
Reply 14 of 22, by bhtooefr
Hold up, if the Teradrive has a dedicated EMS page frame in its stock memory map... that means that you'd need to configure EMS in whatever that thing has for CMOS configuration.
You also won't be able to use the Lo-Tech EMS card, unless you disable the built-in EMS.
Reply 15 of 22, by Jo22
I admit I do know very little about the Teradrive, but the use of the SIMM memory can sometimes be configured in the CMOS utility.
If Shadow Memory or similar is disabled, it may not fill the gap between 640KB and 1MB.
The SIMM memory is then "mapped" beyond the 1MB boundary.
Or not mapped at all, depending on how we look at it:
Early 286s machines lacked the ability to relocate memory and skipped the UMA by default
(reasonable, because it was used solely for devices back then and memory was expensive).
Anyway, in this constellation it could be possible to use that UMB card along with on-board memory.
For what ever reason.
Wow, never seen that before. 😳
I thought that all VGA cards have at least 256KB, which is somehow mapped into a 64KB/128KB window.
The other way round is more familiar to me. Hercules cards' video memory can be used for creating UMBs.
I think there was a driver for this.. Anyway, other cards like CGA or EGA have very little memory, too, so it may be possible to not
use bank-switching techniques at all. At least for certain video modes.
I wonder which type of EMS is faster, smoother or more compatible.
The Lo-Tech card has an 8Bit bus, but can do the mapping on it's own, thus lowering system overhead.
And in addition, it has modern memory so access times could be lower.
Reply 16 of 22, by SquallStrife
(Ronnie?)
Going back to the memory map, you mentioned this:
This is the option ROM region. For instance, if you're using a card with the XT-IDE Universal BIOS, the card's ROM will occupy part of or all of this region.
There is 64KB between C000h and CFFFh, 32KB of which will be mapped to the XTIDE BIOS.
So basically out of everything between 640KB and 1024KB, you could potentially use a 32KB block between C000h-C7FFh or C800h-CFFFh for UMB. Is that worth occupying an entire ISA slot? Not IMO.
Reply 17 of 22, by bhtooefr
Jo22 wrote:
I wonder which type of EMS is faster, smoother or more compatible. The Lo-Tech card has an 8Bit bus, but can do the mapping on i […]
System overhead will be basically zero to use any onboard EMS emulation, and the memory will be handled at higher speed - the Lo-Tech card may even be running at half CPU clock speed or so, if it's not handling the zero wait state pin in the way that an AT expects. Combine that with a half bus speed, and even if there's a wait state involved in accessing main memory, that's still only 3 CPU cycles per main memory bus cycle, versus as much as 8 for the Lo-Tech card.
That is assuming that the comments about there being EMS already mapped into the Teradrive's memory are correct, and that it has EMS support in the chipset.
Reply 18 of 22, by matze79
i run the lotech 2Mb EMS Board in a 286 16Mhz.
Even Wing Commander 1 runs very smooth with Sound and the 8Bit EMS Memory Card.
Its not so bad.. The Heatland EMS Driver for Onboard Memory is also no speed demon.
You can hardly tell any difference using the lotech board or onboard ems..
Reply 19 of 22, by keenerb
Can't you use the EMS page frame for 64kb of UMB if you're not using EMS? Using drdos himem.sys with /chipset:RAM?
