First post, by jim78b
- Member
I have a Good PC Intel core 7 .quadro card ...16giga of ram .But with The Bright 3d pixel shader filter i See The sound is choppy ...why ?
wrote:i See The sound is choppy ...why ?
What a mystery.
Are you trying to run the game Full Throttle, then? Are you using the standard version of DOSBox? Is the sound correct with standard settings?
Yes i use dosbox standard .I use sound blaster 16 ...why do You Tell me a mistery?
Your choice of words is just very poor.
I think your concerns were addressed the last time you posted here.
dosbox direct3d pixel shaders
You are conceited And arrogant.i am italian .why don't you try to learn My language?.it is Easy to hide behind a PC.
Professor
Instead of addressing your firefighting I will try to help you with your question:
Could you post your DOSBox config file? That might shed some light on this. Perhaps also your full system specs instead of just "Good PC Intel core 7 .quadro card ...16giga of ram" ?
World's foremost 486 enjoyer.
Ok thanks Very much later i Will send You.
intel core i-7 -4770 CPU 3.40 ghz
RAM 16 giga
win7 64 bit
graphic card:quadro k600
