First post, by jim78b
I have a Good PC Intel core 7 .quadro card ...16giga of ram .But with The Bright 3d pixel shader filter i See The sound is choppy ...why ?
Reply 1 of 8, by Jorpho
What a mystery.
Are you trying to run the game Full Throttle, then? Are you using the standard version of DOSBox? Is the sound correct with standard settings?
Reply 2 of 8, by jim78b
Yes i use dosbox standard .I use sound blaster 16 ...why do You Tell me a mistery?
Reply 3 of 8, by Jorpho
Your choice of words is just very poor.
I think your concerns were addressed the last time you posted here.
dosbox direct3d pixel shaders
Reply 4 of 8, by jim78b
You are conceited And arrogant.i am italian .why don't you try to learn My language?.it is Easy to hide behind a PC.
Reply 5 of 8, by jim78b
Professor
Reply 6 of 8, by keenmaster486
Instead of addressing your firefighting I will try to help you with your question:
Could you post your DOSBox config file? That might shed some light on this. Perhaps also your full system specs instead of just "Good PC Intel core 7 .quadro card ...16giga of ram" ?
World's foremost 486 enjoyer.
Reply 7 of 8, by jim78b
Ok thanks Very much later i Will send You.
Reply 8 of 8, by jim78b
intel core i-7 -4770 CPU 3.40 ghz
RAM 16 giga
win7 64 bit
graphic card:quadro k600
